I am at a loss to figure out the JSON format for the Alexa Applestrudel node for a text command. I have it working for "speak" but just can't get it right for "text command".
I do not think one is defined for custom setting.
You can feed in a string msg properties for command and device, if set for textcommand
e.g.
[{"id":"cd9b8bf8.ead0c8","type":"alexa-remote-routine","z":"bf9e1e33.030598","name":"","account":"c8738129.d902c","routineNode":{"type":"textCommand","payload":{"text":{"type":"msg","value":"payload"},"devices":{"type":"msg","value":"topic"}}},"x":400,"y":140,"wires":[["c9c82a4a.804d18"]]},{"id":"c9c82a4a.804d18","type":"debug","z":"bf9e1e33.030598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":600,"y":140,"wires":[]},{"id":"55ff61e8.c4ce78","type":"inject","z":"bf9e1e33.030598","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Lounge","payload":"turn lounge 1 to 5 percent","payloadType":"str","x":120,"y":140,"wires":[["cd9b8bf8.ead0c8"]]},{"id":"c8738129.d902c","type":"alexa-remote-account","name":"alexa remote 2","authMethod":"proxy","proxyOwnIp":"localhost","proxyPort":"3456","cookieFile":"","refreshInterval":"14","alexaServiceHost":"layla.amazon.co.uk","amazonPage":"amazon.co.uk","acceptLanguage":"en-GB","userAgent":"","useWsMqtt":"on","autoInit":"off"}]
Enter your command and device in the inject node.
Ah, thanks. I was not aware that if you changed the view of the devices it changed the type of input as well.
What is a "text command"?
In the routine node you can send a text command, anything you would say to alexa e.g "turn on lounge light" , "what is the weather", etc.
I don't believe that I'm just finding out about this now!!! ![]()
Has it been a facility for a long time?
On Github, I think since some 3 years. Up to version 5 now, started at 1
The feature was added to the remote2 plain.sh in december 2020
2020-12-12: v0.17 added textcommand which lets you send anything via CLI you would otherwise say to Alexa
Only missed it for a year then ![]()
I thought it might be of interest to share what I am using this capability for.
I have automated my house via Alexa using these nodes. But it bothers me to have my home automation commands going out to the cloud and back.
So I have recently installed Rhasspy on a Pi and my home ubuntu server and am now using that for all of the home automation commands. Working fairly well so far.
What I am using the text command for is to send any verbal request given Rhasspy that Rhasspy does not understand as a home automation command to Alexa via the text command. Then I route the Alexa response back through Rhasspy to the originating Rhasspy satellite. It is a little delayed but works so far. I will continue with some tweaks to make it flawless.
At the moment, I am using an old Pi to convert text to speech and I've wired the output of it to headphones and glued headphone earpiece next to mic input on a cheap Alexa Flex
All works well
But when I saw about this text command - I thought - I'll be able to send my desired command direct to the Flex ![]()
But (as with everything to do with this sort of thing) it doesn't work for the thing I want it work for
i.e
If I say tell my pi to say "Alexa, ask cheerlights to change to colour red" - my pi speaks this into my Flex and the flex responds correctly
But if I send the text command "ask cheerlights to change to colour red" - I'm getting "cheerlights isn't responding"
So it's failed straight out of the box for me ![]()
I'll stick with my "acoustic coupler" method for now ![]()
Did you to the init for applestrudel where you had to enter your Amazon userid and password?
