From where is this text coming?
Thanks @Colin and @jbudd
I appreciate the help.
This is all you need
[{"id":"c25db9775fae4d50","type":"ui-button","z":"bdd7be38.d3b55","group":"4f87bd59a15b847e","name":"Hold","label":"Default label","order":10,"width":"1","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"X","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","x":430,"y":4100,"wires":[["51a816902115fc76"]]},{"id":"4ac2396cf2f9e57d","type":"inject","z":"bdd7be38.d3b55","name":"","props":[{"p":"ui_update.label","v":"HOLD","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":250,"y":4100,"wires":[["c25db9775fae4d50"]]},{"id":"51a816902115fc76","type":"debug","z":"bdd7be38.d3b55","name":"debug 84","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":610,"y":4100,"wires":[]},{"id":"4f87bd59a15b847e","type":"ui-group","name":"test","page":"c6ff182a4185f2f2","width":"6","height":"1","order":1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"c6ff182a4185f2f2","type":"ui-page","name":"Test page","ui":"ID-BASE-1","path":"/testpage","icon":"home","layout":"grid","theme":"33622591401a2c6e","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":1,"className":"","visible":true,"disabled":false},{"id":"ID-BASE-1","type":"ui-base","name":"Dashboard","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-control","ui-notification","ui-gauge-classic"],"showPathInSidebar":false,"headerContent":"page","titleBarStyle":"default","showReconnectNotification":false,"notificationDisplayTime":"1","showDisconnectNotification":true,"allowInstall":true},{"id":"33622591401a2c6e","type":"ui-theme","name":"Compact","colors":{"surface":"#ffffff","primary":"#0094ce","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"density":"default","pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"0px"}},{"id":"b031cb43fd97ae6a","type":"global-config","env":[],"modules":{"@flowfuse/node-red-dashboard":"1.26.0"}}]
I would not be be at all surprised to find this behaviour in other ui nodes with both input and output.
Also it might not only be msg.ui_update that is wrongly forwarded, other message properties may be retained.
No time to test it, i am already late for a pint of ale!
(Thanks)
Sorry but this is what I sent:
[{"id":"020352927c165a64","type":"ui-button","z":"b39000460508d582","group":"6f4a6f88bfbb219b","name":"Hold","label":"","order":10,"width":"1","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"X","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","x":5610,"y":890,"wires":[["52ba28d889a8d6fb"]]},{"id":"9ac368e01da4aa5f","type":"change","z":"b39000460508d582","name":"Normal","rules":[{"t":"set","p":"ui_update.label","pt":"msg","to":"PASS","tot":"str"},{"t":"set","p":"ui_update.buttonColor","pt":"msg","to":"blue","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":5450,"y":870,"wires":[["020352927c165a64"]]},{"id":"e00e37f0d00a65c8","type":"change","z":"b39000460508d582","name":"Hold","rules":[{"t":"set","p":"ui_update.label","pt":"msg","to":"HOLD","tot":"str"},{"t":"set","p":"ui_update.buttonColor","pt":"msg","to":"red","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":5440,"y":910,"wires":[["020352927c165a64"]]},{"id":"52ba28d889a8d6fb","type":"ui-text","z":"b39000460508d582","group":"6f4a6f88bfbb219b","order":12,"width":"2","height":"1","name":"","label":"Test","format":"{{msg.payload}}","layout":"row-spread","style":false,"font":"","fontSize":16,"color":"#717171","wrapText":false,"className":"","x":5870,"y":890,"wires":[]},{"id":"eb989fcd67e25fa7","type":"inject","z":"b39000460508d582","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0","payloadType":"num","x":5320,"y":810,"wires":[["9ac368e01da4aa5f"]]},{"id":"35a8e73703cbc8c0","type":"inject","z":"b39000460508d582","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":5320,"y":950,"wires":[["e00e37f0d00a65c8"]]},{"id":"6f4a6f88bfbb219b","type":"ui-group","name":"Group 1","page":"b9b507aa5c5840c2","width":"10","height":1,"order":1,"showTitle":false,"className":"","visible":true,"disabled":"false","groupType":"default"},{"id":"b9b507aa5c5840c2","type":"ui-page","name":"Down/Up load speed tester","ui":"379027033ed5c83a","path":"/page1","icon":"home","layout":"flex","theme":"84a68e3f4c6f8cdc","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":1,"className":"","visible":true,"disabled":false},{"id":"379027033ed5c83a","type":"ui-base","name":"My Dashboard","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"default","titleBarStyle":"default","showReconnectNotification":true,"notificationDisplayTime":1,"showDisconnectNotification":true,"allowInstall":true},{"id":"84a68e3f4c6f8cdc","type":"ui-theme","name":"Default Theme","colors":{"surface":"#63452c","primary":"#0094ce","bgPage":"#63452c","groupBg":"#63452c","groupOutline":"#cccccc"},"sizes":{"density":"default","pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}}]
Again:
Thanks to you both.
