I'm trying to put a file from a local windows machine to an FTP site. I'm using the 'node-red-contrib-ftp
' module.
I have setup the username and password correctly and I've confirmed with filezilla that I can connect from the local computer to the FTP site.
However, when I try to put using node-red it gives me an error "Non-anonymous sessions must use encryption"
I see a data connection encryption check box, I check it and update but doesn't seem to stick when I deploy.
Any idea's what I need to change?
I know my creds are correct and I am using port 21.
Hi
Which FTP node are you using?
Have you tried others?
I am using the 'https://flows.nodered.org/node/node-red-contrib-ftp' node
Also, I was able to fix it by editing the script,
I changed the default to true.
'host': n.host || 'localhost',
'port': n.port || 21,
'secure': n.secure || false,
to
'secure': n.secure || true,
and it started to work now.
If you are using plain FTP (not SFTP or FTPS) then the message is giving you a very important clue. That's so say that you will be sending your ID and Password in clear text to the server.
This may not be a big problem on a private home network but it is a massive problem over a public network and the Internet.
It would also be a big problem in an enterprise environment.
Also, you would want to make absolutely certain that you do not use the same password anywhere else - ever. (Good practice anyway of course).
@TotallyInformation Thank you for the information, this is just to update somethings on a FTP site. I understand the risks of it but the third party I am working with have it set up that way.
That being said, this is not sensitive information at all. Just some updates in a CSV file.
You should also raise an issue against that node if you can as it’s obviously not handling that input option parameter correctly. ( it’s probably a true vs “true” (I’m guessing))
Will notify them about the issue. You are probably correct about true vs "true".
