Function node displays `The workspace contains some nodes that are not properly configured:`
I'm using some javascript in a function node, but when I deploy it, I get a red triangle on the node, and a pop-up saying The workspace contains some nodes that are not properly configured: and options is highlighted from this line;
const parts = new Intl.DateTimeFormat('en-GB', options).formatToParts(now);
The javascript runs ok, and does what it's supposed to do, but it's a pain having to acknowledge the popup every time I deploy.
Is there a problem with the code?
// Get or initialize chart data
let chartData1 = flow.get("chartData1") || {
    x: [],
    y: []
// Handle flush request
if (msg.topic === "flush") {
    msg.payload = [{
        x: chartData1.x,
        y: chartData1.y,
        type: "line"
// Validate input
if (!msg.payload || typeof msg.payload.grid !== "number") {
    return null;  // drop if invalid
// Normal update: append new point
const now = new Date();
const options = {
    timeZone: 'Europe/London',
    year: 'numeric',
    month: '2-digit',
    day: '2-digit',
    hour: '2-digit',
    minute: '2-digit',
    second: '2-digit',
    hourCycle: 'h23' // use 24-hour format
const obj = Object.fromEntries(parts.map(p => [p.type, p.value]));
const time = `${obj.year}-${obj.month}-${obj.day} ${obj.hour}:${obj.minute}:${obj.second}`;
const value = msg.payload.grid;
chartData1.x.push(time);
chartData1.y.push(value);
// Limit size to 30 minutes
if (chartData1.x.length > 360) {
    chartData1.x.shift();
    chartData1.y.shift();
node.status("No of data points = " + chartData1.x.length);
// Save updated context
flow.set("chartData1", chartData1);
// Return just the latest point
msg.payload = [{
    x: [time],
    y: [value],
    type: "line"
Code looks fine and if I place in a function node I get no Red triangle.
Is there something in the set up tab?
Have you tried deleting the node and adding a new function node?
No
Yes, same result.
I’ve also tried changing the name of the constant ‘options’, and also moving the declaration to the top of the code.
Node-RED version: v4.1.0
Node.js version: v20.19.4
Linux 6.8.0-1030-oracle arm64 LE (Ubuntu)
Oracle cloud server
I am wondering if the .formatToParts(now) is the issue. Have you tried now() or Date.now()
I am seeing the same thing. If you put the options inline in the call it is ok.
const parts = new Intl.DateTimeFormat('en-GB', {
    year: 'numeric',
    month: '2-digit',
    day: '2-digit',
    hour: '2-digit',
    minute: '2-digit',
    second: '2-digit',
}).formatToParts(now);
I think it must be a bug in the syntax checker code. Hovering over options (in the original) which has a red line under it says that there is no matching overload, but the popup is not large enough to see exactly what it is complaining about, and I can't work out how to see all of the message.
I had that, you can also get rid of the error by having /** @type {Intl.DateTimeFormatOptions} */ just before the const options = { line
This is why: Monaco clarification - #32 by Steve-Mcl
I'd forgotten that whole conversation, on exactly the same problem :grin:
Adding /** @type {Intl.DateTimeFormatOptions} */ certainly clears the problems, but the strange thing is that I started using that code over 4 weeks ago with no issues whatsoever, and it only started showing yesterday after I re-opened the function node just to look at something. I made no changes, but when I clicked ‘Done’ to exit the node, the issue started.
(I’ll be glad when the ‘click outside the box’ issue is rolled back :wink: )
But all good now, thanks for all of the responses.
