I have a Node-RED flow that uses an API request for my cycle routes. It returns a huge array up to 2000 points each for elevation, speed & grade. I would like to pull these values out and plot them onto a ride graph. Is there a way of being able to do this with a loop function as the amount will differ per trip and I don’t fancy having to pull each one out individually.
Example
Path for first elevation payload.trip.track_points[0].e
@JamesMcCarthy79
James, I assume that you have copied and pasted this post from https://community.home-assistant.io/t/node-red-function-to-get-multiple-arrays/200024
The post above is missing the screenshot, please edit the post using the pencil icon and add your screenshot image.
@Paul-Reed I did indeed but felt maybe this was a better place to post my question.
...a ride graph would need a timestamp associated with each object on the array, wouldn't it?
I don't see this in your example.
Besides, the transformation to a chart datasets can be done in a function node, using js. Lopping over the array is not a problem in there...
In that case, can you share how it's done for the OP.
...I can share an example later, how I do that for other data from my setup.
In the example screenshot above you can see payload.trip.track_points[0].t is the timestamp in question
Ah, OK...didn't get that while browsing from my mobile
I tried and quickly modify an example I use for another case, that might work for you.
At least it should give you some hints on how this might work.
Maybe @Paul-Reed is able to comment or improve, as I am not a JS guy
let array = msg.payload.trip.track_points;
var time=0;
var elevation=0;
var speed=0;
var grade=0;
var i=0;
var chartarray = [[]];
for(let i = 0; i < array.length; i++) {
time = array[i].t;
elevation = array[i].e;
speed = array[i].x;
grade = array[i].y;
chartarray[0][i] = {"x":time,"y":elevation};
chartarray[1][i] = {"x":time,"y":speed};
chartarray[2][i] = {"x":time,"y":grade};
var chart = [{
"series":["Elevation", "Speed", "Grade"],
"data":chartarray,
"labels":[""]
msg.payload = chart;
msg.topic = "trip"
Info on how a dashboard chart works can be found here: https://github.com/node-red/node-red-dashboard/blob/master/Charts.md
Neither am I
Perhaps @JamesMcCarthy79 can try with his data source, and let us know if there is a problem.
