Function to store data from csv to table?
Hi programers. I need a function that allows to store data from csv node to a table???
A table in a database or what?
It would also be good if you can post your flow and explain where you are stuck. As the purpose of this forum is to help you learn.
Please read this post before posting How to share code or flow json
what i'am trying to do is to save data from modal to pdf file. i figure out a solution but i find that it only write on the first line no back to line on every save?
