I put a litte photo resistor in my Alexa Echo dot so when the light ring lights up an esp8266 detects that and triggers a binary_sensor. With that information I power on/off an LED Strip (Because I sometimes I don’t see the ring on the echo dot and it’s kind of a cool effect).
So the ring is lightning up for around 3 seconds or something and then it should go back to the state it was before it was turned on by the Alexa binary_sensor (for example some color fading etc.). How do I achieve this?
Here’s a screenshot of the flow with the compelte .msg on the right.
thanks a lot
chris
