Can someone help me.. I have node red integration with tuya cloud API and I need to check my smart plug consumption per day. I try to send command total power working well but if I send command power day the result sign invalid. I try send command power day from postman working.
the result working (total power):
problematic results (power day):
Below this my node red.
"id": "a6c422e0c1f1059f",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": "",
"env": []
"id": "30e07ae83d05587c",
"type": "function",
"z": "a6c422e0c1f1059f",
"func": "var url = \"https://openapi.tuyaus.com/v1.0/token?grant_type=1\";\nvar t = msg.time;\nvar sign = msg.payload;\nvar client_id = flow.get(\"tuya_client_id\");\nmsg.headers ={\n \"sign_method\": \"HMAC-SHA256\",\n \"client_id\" : client_id,\n \"t\": t.toString(),\n \"sign\": sign.toUpperCase(),\n },\n msg.payload = '';\n msg.url = url;\n msg.method = \"GET\";\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 560,
"y": 100,
"70c77b5c60b93b02"
"id": "70c77b5c60b93b02",
"type": "http request",
"method": "use",
"ret": "obj",
"paytoqs": "ignore",
"url": "",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 730,
"y": 100,
"1d39ccf2e051c5bd"
"id": "486b1e5360769c46",
"type": "inject",
"props": [
"p": "time",
"v": "",
"vt": "date"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 90,
"y": 100,
"86ca345a20fb2c40"
"id": "86ca345a20fb2c40",
"type": "function",
"name": "Create signStr",
"func": "var client_id = flow.get(\"tuya_client_id\");\nvar t = msg.time;\n\n\nvar method = \"GET\";\nvar sign_url = \"/v1.0/token?grant_type=1\";\n\n// Couldn't get nodered to process an empty string so this is a hash of an empty file\nvar content_hash = \"e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855\";\nvar string_to_sign = method+\"\\n\"+content_hash+\"\\n\"+\"\"+\"\\n\"+sign_url;\nvar signStr = client_id+t+string_to_sign;\n\nmsg.payload = signStr;\nmsg.time = msg.time;\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "// Code added here will be run once\n// whenever the node is started.\nvar client_id = \"gmkrt9qagn7f5puwmgws\";\nvar user_id = \"arcontrol.ytm3@gmail.com\";\nvar device_id = \"eb893b4451760756a9nepw\";\nflow.set(\"tuya_client_id\", client_id);\nflow.set(\"tuya_user_id\", user_id );\nflow.set(\"device_id\", device_id );",
"finalize": "",
"libs": [],
"x": 260,
"y": 100,
"efeb97daa09e5d4c"
"id": "efeb97daa09e5d4c",
"type": "hmac",
"name": "Sign",
"algorithm": "HmacSHA256",
"key": "cffcc28cfaef4e88a415b5b2d3842ff5",
"x": 410,
"y": 100,
"30e07ae83d05587c"
"id": "edc2de9f19eaf09d",
"type": "comment",
"name": "Get Access Token",
"info": "",
"x": 110,
"y": 60,
"id": "117862ed28c55bd6",
"type": "comment",
"name": "Get Total",
"info": "",
"x": 80,
"y": 260,
"id": "1d39ccf2e051c5bd",
"type": "function",
"name": "Extract Token from Response",
"func": "var data = msg.payload;\nvar access = data.result.access_token;\nvar refresh = data.result.refresh_token;\n\nvar creds ={\n \"access_token\" : access,\n \"refresh_token\" : refresh\n}\nflow.set(\"tuya\", creds);\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 940,
"y": 100,
"7c9e38a0ba3edfae"
"id": "536be60460901270",
"type": "inject",
"props": [
"p": "time",
"v": "",
"vt": "date"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 90,
"y": 300,
"7cca48367d988c0f"
"id": "7cca48367d988c0f",
"type": "function",
"func": "var creds = flow.get(\"tuya\");\nvar access_token = creds.access_token;\nvar deviceID = msg.deviceID;\nvar t = msg.time;\nvar client_id = flow.get(\"tuya_client_id\");\nvar device_id = flow.get(\"device_id\");\nvar token = access_token;\nvar method = \"GET\";\nvar sign_url = \"/v1.0/devices/\"+device_id+\"/statistics/total?code=add_ele\";\nvar content_hash = \"e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855\";\nvar string_to_sign = method+\"\\n\"+content_hash+\"\\n\"+\"\"+\"\\n\"+sign_url;\nvar signStr = client_id+token+t+string_to_sign;\n\nmsg.payload = signStr;\nmsg.time = msg.time;\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 240,
"y": 300,
"be44fa094e1b9cc7"
"id": "be44fa094e1b9cc7",
"type": "hmac",
"name": "Sign",
"x": 390,
"y": 300,
"37de899f6fee6d54"
"id": "37de899f6fee6d54",
"type": "function",
"func": "var deviceID = msg.deviceID;\nvar url = \"https://openapi.tuyaus.com\";\nvar t = msg.time;\nvar method = \"GET\";\nvar client_id = flow.get(\"tuya_client_id\");\nvar device_id = flow.get(\"device_id\");\nvar creds = flow.get(\"tuya\");\nvar token = creds.access_token;\nvar sign = msg.payload;\nmsg.headers ={\n \"sign_method\": \"HMAC-SHA256\",\n \"client_id\" : client_id,\n \"t\": t.toString(),\n \"mode\" : \"cors\",\n \"Content-Type\": \"application/json\",\n \"sign\": sign.toUpperCase(),\n \"access_token\" : token\n },\n msg.payload = '';\n msg.url = url+\"/v1.0/devices/\"+device_id+\"/statistics/total?code=add_ele\";\n msg.method = \"GET\";\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 520,
"y": 300,
"417fb6f2925212f9"
"id": "417fb6f2925212f9",
"method": "use",
"ret": "obj",
"url": "",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"senderr": false,
"x": 670,
"y": 300,
"0ab9eb54836bb821"
"id": "0ab9eb54836bb821",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"complete": "payload",
"targetType": "msg",
"statusVal": "payload",
"statusType": "auto",
"x": 850,
"y": 300,
"id": "72cc7ea85efc352a",
"type": "comment",
"name": "GetDay",
"info": "",
"x": 70,
"y": 360,
"id": "2ca33bf60df7d7bd",
"type": "comment",
"name": "GetStatus",
"info": "",
"x": 80,
"y": 160,
"id": "7c9e38a0ba3edfae",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"x": 1150,
"y": 100,
"id": "87990bab98005173",
"type": "inject",
"props": [
"p": "time",
"v": "",
"vt": "date"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 90,
"y": 200,
"2b37c286a860e920"
"id": "2b37c286a860e920",
"type": "function",
"func": "var creds = flow.get(\"tuya\");\nvar access_token = creds.access_token;\nvar deviceID = msg.deviceID;\nvar t = msg.time;\nvar client_id = flow.get(\"tuya_client_id\");\nvar device_id = flow.get(\"device_id\");\nvar token = access_token;\nvar method = \"GET\";\nvar sign_url = \"/v1.0/devices/\"+device_id;\nvar content_hash = \"e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855\";\nvar string_to_sign = method+\"\\n\"+content_hash+\"\\n\"+\"\"+\"\\n\"+sign_url;\nvar signStr = client_id+token+t+string_to_sign;\n\nmsg.payload = signStr;\nmsg.time = msg.time;\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 240,
"y": 200,
"6770b78a12f4a539"
"id": "6770b78a12f4a539",
"type": "hmac",
"name": "Sign",
"x": 390,
"y": 200,
"2e64ee78353c5ddf"
"id": "2e64ee78353c5ddf",
"type": "function",
"func": "var deviceID = msg.deviceID;\nvar url = \"https://openapi.tuyaus.com\";\nvar t = msg.time;\nvar method = \"GET\";\nvar client_id = flow.get(\"tuya_client_id\");\nvar device_id = flow.get(\"device_id\");\nvar creds = flow.get(\"tuya\");\nvar token = creds.access_token;\nvar sign = msg.payload;\nmsg.headers ={\n \"sign_method\": \"HMAC-SHA256\",\n \"client_id\" : client_id,\n \"t\": t.toString(),\n \"mode\" : \"cors\",\n \"Content-Type\": \"application/json\",\n \"sign\": sign.toUpperCase(),\n \"access_token\" : token\n },\n msg.payload = '';\n msg.url = url+\"/v1.0/devices/\"+device_id;\n msg.method = \"GET\";\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 520,
"y": 200,
"8c4ae4a5e2dc27e7"
"id": "8c4ae4a5e2dc27e7",
"method": "use",
"ret": "obj",
"url": "",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"senderr": false,
"x": 670,
"y": 200,
"74ea0f207b97b951"
"id": "74ea0f207b97b951",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"x": 850,
"y": 200,
"id": "d41ce93a1cdae79a",
"type": "inject",
"props": [
"p": "time",
"v": "",
"vt": "date"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 95,
"y": 400,
"662328987632219e"
"id": "662328987632219e",
"type": "function",
"func": "var creds = flow.get(\"tuya\");\nvar access_token = creds.access_token;\nvar deviceID = msg.deviceID;\nvar t = msg.time;\nvar client_id = flow.get(\"tuya_client_id\");\nvar device_id = flow.get(\"device_id\");\nvar token = access_token;\nvar method = \"GET\";\nvar sign_url = \"/v1.0/devices/\"+device_id+\"/statistics/days?code=add_ele&start_day=20221011&end_day=20221011\";\nvar content_hash = \"e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855\";\nvar string_to_sign = method+\"\\n\"+content_hash+\"\\n\"+\"\"+\"\\n\"+sign_url;\nvar signStr = client_id+token+t+string_to_sign;\n\nmsg.payload = signStr;\nmsg.time = msg.time;\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 245,
"y": 400,
"0623a62f6bfa6dab"
"id": "0623a62f6bfa6dab",
"type": "hmac",
"name": "Sign",
"x": 395,
"y": 400,
"c4ea7a7e08833d5d"
"id": "c4ea7a7e08833d5d",
"type": "function",
"func": "var deviceID = msg.deviceID;\nvar url = \"https://openapi.tuyaus.com\";\nvar t = msg.time;\nvar method = \"GET\";\nvar client_id = flow.get(\"tuya_client_id\");\nvar device_id = flow.get(\"device_id\");\nvar creds = flow.get(\"tuya\");\nvar token = creds.access_token;\nvar sign = msg.payload;\nmsg.headers ={\n \"sign_method\": \"HMAC-SHA256\",\n \"client_id\" : client_id,\n \"t\": t.toString(),\n \"mode\" : \"cors\",\n \"Content-Type\": \"application/json\",\n \"sign\": sign.toUpperCase(),\n \"access_token\" : token\n },\n msg.payload = '';\n msg.url = url+\"/v1.0/devices/\"+device_id+\"/statistics/days?code=add_ele&start_day=20221011&end_day=20221011\";\n msg.method = \"GET\";\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 525,
"y": 400,
"73d92ece690a2e23"
"id": "73d92ece690a2e23",
"method": "use",
"ret": "obj",
"url": "",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"senderr": false,
"x": 675,
"y": 400,
"e684d0839b0833d3"
"id": "e684d0839b0833d3",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"x": 855,
"y": 400,
Thanks,
wiwan
