Get value based on object.id
Hi.
I have an object with an array of objects. I want to use a function node to get one spesific value based on the object id.
So if I only want temp from a speseific device/object
if msg.payload.object.id == "2920009404" then msg.payload = msg.object.temp?
Have a look at the array filter function.
Thanks for the tip. Solved it with this code.
msg.payload = msg.payload.devices.filter(el => el.id === "V004b11e12")
msg.payload = msg.payload[0].data.controlSignal
