JSON Array Filtering - Function Node
Using the function node please could someone help me filter the area_id value when its set to RT in the below array?
msg.payload = msg.payload.CA_MSG.filter(el => el.area_id.includes("RT"))
See this post from earlier today which asks an almost identical question. Filter Array of Objects
[Edit] Note that if you are using the filter function you have to call filter on the Array, which is msg.payload.trains, not msg.payload.CA_MSG, and you have to check for equality (at least I assume that is what you want) so the test is el.area_id === "RT")
[Edit] as pointed out below that should be el.CA_MSG.area_id
Thanks for your reply Colin.
I am trying to filter every object that has RT set in the area_id field.
Could you help as it's still not filtering properly?
msg.payload = msg.payload(el => el.area_id === "RT")
Looking at your original debug image.
Your object paths are incorrect, the array is in msg.payload.trains, and area_id is in CA_MSG.
msg.payload = msg.payload.trains.filter(el => el.CA_MSG.area_id === "RT")
also you missed the filter function name.
