Getting a value from a json property with space in the name
Hi, Guys!
I'm receiving the JSON string below and converting it to a JavaScript Object.
{"electricFaultStamp":{"id":"Timed overcurrent relay fault","Ansi Code":51,"Flag":1,"Lock":0,"Time Stamp":"Thu Jan 1 00:16:10 1970"}}
Then, I'm using a function node to try to get and use the Time Stamp value using the code below:
var time = msg.payload.electricFaultStamp.Time Stamp; // I also tried (Time_Stamp)
msg.payload= time;
but I was not able to get this value... Is it allowed to have a property name with space in the middle of the name in a Javascript object?
Take a look in the forums, something similar was just answered a short time ago.
Tks... I've just found it on stackflow. I used:
var time = msg.payload.electricFaultStamp['Time Stamp'];
You can just grab the path from debug...
