Getting Node-RED 5 in FlowFuse Community Edition
I've just started playing around with FlowFuse CE and I noticed that it is still running Node-RED 4.1.13. Is there some way to get 5.0.4? I tried the recommended upgrade instructions by downloading the latest docker compose yml file and then doing 'docker pull flowfuse/node-red:latest' but the version remained at 4.1.13.
there is an image tagged [latest-5.0.x]
There is a complete list here:
Thanks for that info.
Clearly I don't know what I'm doing. I did docker pull flowfuse/node-red:latest-5.0.x. Does that seem correct?
I got the following:
latest-5.0.x: Pulling from flowfuse/node-red
77e1316c7113: Pull complete
003c89ad06b5: Pull complete
39d15e01020d: Pull complete
35db90a9633b: Pull complete
679e094cb4a6: Pull complete
2bb70416baa0: Pull complete
0c588c236bb8: Pull complete
443627c3cf35: Pull complete
3925f1464fe6: Pull complete
b2369a4cfaf2: Pull complete
9d20ac4fa559: Pull complete
a5973c68426c: Pull complete
0b0637ad84f9: Pull complete
b8b5c63906b3: Pull complete
55ef7c9368c7: Pull complete
4f4fb700ef54: Pull complete
85dc09af440a: Pull complete
4497773acfc2: Pull complete
b811bf539da6: Pull complete
fcae09a5a72c: Pull complete
6fe292fbc61a: Pull complete
63d2afeb6c2e: Pull complete
c4cb9b1e2181: Pull complete
702ed771514e: Pull complete
9bfd5cae6480: Pull complete
d4a6e1bf336a: Download complete
Digest: sha256:6e513dceabeed8caf53c1bc9363ca507830a7e2826e45cd005d74138d9a9763a
Status: Downloaded newer image for flowfuse/node-red:latest-5.0.x
docker.io/flowfuse/node-red:latest-5.0.x
However I still have 4.1.13 when I create a new instance.
Obviously I'm missing something.
Under Admin Settings, I found 'Templates' which seems like the logical place to specify the Node-RED version I want, but I don't see any place to do that in that form.
In order to present different versions of node-red you need to set up the stack in admin settings: Administering FlowFuse • FlowFuse Docs
disclaimer : I have no experience with flowfuse, I only use node-red directly.
The image name/tag in the pull was the obvious thing.
Now you probably need to specify this tag in your configuration somewhere to actually use it.
Otherwise the default will be used.
Thank you! That was the trick.
Thank you for your help. That got me digging and then Steve posted about the Stack settings.
