Hi
This is my first post so I would like to use this opportunity to express gratitude to the developers and to the community!
Current Setup:
We run node-red on a server with multiple users that create and edit flows from time to time.
We use the Projects feature with remote origin.
We are using Node-red instance with custom tailored Firebase Authentication. Based on the httpAdminMiddleware function that checks JWT token etc. this part is working fine.
But the git commits are all authored by the same user. As set in "User Settings" -> "Git Config".
Requirement: To have a changes "blame log" a user's username or email to be added to each commit
git does have an option to do it through the --author option to the commit command and we have the user's username and email as a header in the request
but how to get one to another ?
right now we did a hack in the
.../node-red/node-red/blob/master/packages/node_modules/%40node-red/runtime/lib/storage/localfilesystem/projects/git/index.js
we added
if(args[0]==="commit"){
args.push("--author");
args.push("globalEmailOverride <"+globalEmailOverride+">");
and we set globalEmailOverride with another hack...
but is there a better way?
