Hi there,
when I try to generate a new github ssh key in node red, running in a docker container, based on alpine, on a arm32v7 base image,
Nodered throws this error.
can be repeated doing this:
docker run -d -p1880:1880 --name nodered echteler/nodered:balluff_arm_dev
when the prompt tells you to generate a new ssh key to clone a repo, NR crashes with those logs:
Welcome to Node-RED
6 Aug 08:32:11 - [info] Node-RED version: v0.20.7
6 Aug 08:32:11 - [info] Node.js version: v10.15.3
6 Aug 08:32:11 - [info] Linux 4.9.184-linuxkit arm LE
6 Aug 08:32:14 - [info] Loading palette nodes
6 Aug 08:32:32 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
6 Aug 08:32:32 - [warn] rpi-gpio : Cannot find Pi RPi.GPIO python library
6 Aug 08:32:34 - [info] Dashboard version 2.15.5 started at /ui
6 Aug 8:32:34 - [s7comm-Error] - Installation of Module net-keepalive failed because we might be on the wrong OS. OS=linux
6 Aug 8:32:34 - [s7comm-Info] - Debug configuration for logLevelNodeS7:{"debug":0,"silent":true}
6 Aug 8:32:34 - [s7comm-Info] - Debug configuration for logLevelNodeRED:{"debug":2,"silent":true}
6 Aug 08:32:36 - [info] Settings file : /data/settings.js
6 Aug 08:32:36 - [info] Context store : 'default' [module=memory]
6 Aug 08:32:36 - [info] User directory : /data
6 Aug 08:32:36 - [warn] No active project : using default flows file
6 Aug 08:32:36 - [info] Flows file : /data/flows.json
6 Aug 08:32:37 - [warn]
your credentials.
6 Aug 08:32:37 - [info] Starting flows
6 Aug 08:32:37 - [info] Started flows
6 Aug 08:32:37 - [info] Server now running at http://127.0.0.1:1880/
6 Aug 08:34:16 - [red] Uncaught Exception:
6 Aug 08:34:16 - Error: spawn ssh-keygen ENOENT
at Process.ChildProcess._handle.onexit (internal/child_process.js:240:19)
at onErrorNT (internal/child_process.js:415:16)
at process._tickCallback (internal/process/next_tick.js:63:19)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! node-red-docker@1.0.0 start: `node $NODE_OPTIONS node_modules/node-red/red.js -v $FLOWS "--userDir" "/data"`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the node-red-docker@1.0.0 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /usr/src/node-red/.npm/_logs/2019-08-06T08_34_17_152Z-debug.log
