Global Environment Variables credentials are lost
(Somewhat related to:
0. Reading global environment variable from function node
  1. Flow Environment credentials are lost )
Hello. I am having trouble reliably using credential values saved as Global Environment Variables.
First I had the same issue as in (0), where credentials wouldn't be returned at all. Then I've upgraded to Node-RED v3.1.3 and now I am seeing behaviour similar to (1), just there it was happening with flow env variables.
Steps to reproduce:
Nothing has changed since
Again: I propose you raise an issue in the NR GitHub repo!
I thought this was closed in #4396 to be included in 3.1.1 release.
This was the PR.
And you are right that such bugs should probably be reported in the GitHub repo and not posted here as discussions.
Reported as #4508.
Thank you for this heads-up. Indeed, it seems to be addressed...
This yet looks to be intentional: The credential shouldn't be lost. It's in the nature of (password like) credentials that - once they pass from the client to the runtime - they'll never make their way back.
Thus you cannot debug them (you'll get __PWRD__ instead), but you should be able to use them.
Have you tried?
Should we move this discussion to GitHub? A contributor has already responded with what I think is an explanation that supports my claim.
I'm not sure how else I'm supposed to use them. In a 'change' or 'function' node I should be able to access the credential value, right? Then I should be able to write that value as a plain text value to msg to be printed to debug.
