While using redis contextStorage as default and use global.get() it results in an error as below.
"Error: Callback must be a function"
Using the below redis package.
GitHub - node-red/node-red-context-redis: A Node-RED Context store plugin backed by Redis
global.set() goes through and my redis-cli has stored the value too that I can query and check.
This doesn't happen with default being filesystem (and obviously memory)
I cannot make redis context as default. I would like both durability + Transactionality hence was trying redis context storage for this purpose.
contextStorage: {
default: {
module: require("node-red-context-redis"),
config: {
host: "127.0.0.1",
port: 6379,
db:0,
password:"mypassword",
I can selectively use redis for storing explicitly without making it default
global.set("myglobalkey","myval","redis");
context.set("mycontextkey","myval2","redis");
global.get("mykey","redis");
context.get("mycontextkey","redis");
Has anyone faced this issue?
