Global var Time not recalling properly
I have a input box on my dashboard with the mode set to time picker.
I pass that value into a function which then stores it as a global variable (using the local file system).
global.set('ShiftEnd1',msg.payload);
So I can see the global variable value in the file system, see it be updated and such so all is great.
However, if I close my browser and relaunch the dashboard site, the values are not going back into the time picker. It shows as if I never put anything in there.
However, I can still look at the local file system and see the "global.json" still has the correct value.
Am I doing something wrong?
What have you done to feed the global saved value into the time picker on startup?
