Google Calendar In node - redirect uri?
The redirect uri in the Google credentials node is documented as "http://node-red.example.com:1880/google-credentials/auth/callback". Does this need to be changed to https? I got an email from Google saying that the project will be removed if the uri is not compliant. The only thing that I could find on their website was that "http" redirect uri is not compliant and it needs to be https.
Thanks for your help.
UPDATE: I changed the uri on my Google developer site to https://. However, the authentication fails with "Error 400: redirect_uri_mismatch - The redirect URI in the request, http://node-red.example.com:1880/google-credentials/auth/callback, does not match the ones authorized for the OAuth client. ". Any chance that will be fixed or is there a workaround?
The workaround to this issue is to either move the status of the project back to "testing" or leave it in "testing". Once I did that, I was able to change the uri back to http://.
Unfortunately, this did not correct the issue. I cannot "re-authenicate" with Google. I have deleted the google credentials config and tried to recreate it but I get an error when Google tries to authenticate the callback .
I have made the hosts entry and when I type in http://node-red.example.com:1880, I do get the Node-RED UI.
UPDATE: I forgot that I had to do the URI authentication step from the computer that NR is running on. Once I did that (and the status of the project was "Testing"), everything worked.
