Google Calendar Integration help
I have integrated Google Calendar into Home Assistant by following the process here and have got the client ID and secret as required.
Then I installed the node-red-node-google and added my credentials in the "google calendar in" node.
My problem is that is also says " Please configure the authorized Redirect URIs of your app to include the following url:
http://homeassistant.local:8123/api/hassio_ingress/xxxxxxxxxxxxxxxxxx" and I don't know where to go to do that.
Thanks.
Following along as I'm in the same predicament.
I know that Google Calendars can auth in HA - following this https://www.home-assistant.io/integrations/calendar.google/
But I'd like more control with node-red vs automations.
So are you using standalone NR or the one integrated into HA by Frenck through the HACS interface ?
Are you getting the same message as the OP or something different ?
You might want to post up your flow also - and info as to your environment and version of NR, NPM and NODEJS
Craig
