hi there here is the flow
I just clean the api key from first node you need your own client secret to use it
[{"id":"a3e4e204.7aa95","type":"inject","z":"818b9061.accc5","name":"","props":[{"p":"tokengoogle","v":"9876876rvbmnöm0uAQSNwF-L9IrZeiR1REsNfmuwwLXylNJs_2RP1-sJ1Ahfgp1dDxBO_Sgdfggfdsfghjkl_ouOPLuBmDzRY&645646554356client_id=78543525656532-6aeecrdib2gdfg78hbcp3un659tgertegdfs656s0gdf3.apps.googleusercontent.com","vt":"str"}],"repeat":"1800","crontab":"","once":true,"onceDelay":"5","topic":"","payloadType":"str","x":310,"y":180,"wires":[["b83b157.44082e8"]]},{"id":"340c6f1.d5a6a9","type":"http request","z":"818b9061.accc5","name":"","method":"POST","ret":"txt","paytoqs":"ignore","url":"https://oauth2.googleapis.com/token","tls":"","persist":false,"proxy":"","authType":"","x":330,"y":260,"wires":[["7f2a2a29.a8aea4"]]},{"id":"b83b157.44082e8","type":"function","z":"818b9061.accc5","name":"set payload and headers","func":"var tokenguncel = msg.tokengoogle;\n\nmsg.payload = tokenguncel;\nmsg.headers = {};\nmsg.headers['content-type'] = 'application/x-www-form-urlencoded';\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":290,"y":220,"wires":[["340c6f1.d5a6a9"]]},{"id":"603a42d2.9227dc","type":"change","z":"818b9061.accc5","name":"token","rules":[{"t":"set","p":"token","pt":"msg","to":"payload.access_token","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":340,"wires":[["50a164a0.11667c"]]},{"id":"7f2a2a29.a8aea4","type":"json","z":"818b9061.accc5","name":"","property":"payload","action":"","pretty":false,"x":350,"y":300,"wires":[["603a42d2.9227dc"]]},{"id":"50a164a0.11667c","type":"change","z":"818b9061.accc5","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.access_token","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":380,"wires":[["e0a7c39e.788e3"]]},{"id":"e0a7c39e.788e3","type":"change","z":"818b9061.accc5","name":"","rules":[{"t":"set","p":"token","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":420,"wires":[[]]},{"id":"dd9550db.49ca7","type":"http request","z":"818b9061.accc5","name":"","method":"GET","ret":"txt","paytoqs":"ignore","url":"https://analytics.googleapis.com/analytics/v3/data/realtime?ids=ga%3A189270063&metrics=rt%3AactiveUsers&dimensions=rt%3Asource&access_type=offline&prompt=consent&key=7jfj87SyBl9jgk67rYaJT-zPIjf3QKIU546hfghfg4l-Jq1787Ec656","tls":"","persist":false,"proxy":"","authType":"","x":650,"y":340,"wires":[["fed0d603.7851d8"]]},{"id":"22fe6840.76cd38","type":"inject","z":"818b9061.accc5","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":true,"onceDelay":"5","topic":"","payload":"","payloadType":"date","x":650,"y":220,"wires":[["5fc9c7e2.fec0d8"]]},{"id":"fed0d603.7851d8","type":"json","z":"818b9061.accc5","name":"","property":"payload","action":"obj","pretty":false,"x":670,"y":380,"wires":[["7752fb57.810384"]]},{"id":"7752fb57.810384","type":"change","z":"818b9061.accc5","name":"","rules":[{"t":"set","p":"online","pt":"msg","to":"payload.totalsForAllResults[\"rt:activeUsers\"]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":420,"wires":[["93080a2b.583878"]]},{"id":"d9b42ea0.92da2","type":"function","z":"818b9061.accc5","name":"set payload and headers","func":"var tokengelen = msg.payload;\nvar bear2 = 'Bearer, ' + tokengelen;\n\nmsg.payload = \"\";\n\nmsg.headers = {\n 'Authorization': \"Bearer \" + tokengelen,\n 'Content-Type': 'application/json'\n};\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":610,"y":300,"wires":[["dd9550db.49ca7"]]},{"id":"5fc9c7e2.fec0d8","type":"change","z":"818b9061.accc5","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"token","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":260,"wires":[["d9b42ea0.92da2"]]},{"id":"93080a2b.583878","type":"ui_template","z":"818b9061.accc5","group":"d8c86af7.92aeb8","name":"analytics","order":2,"width":4,"height":4,"format":"<style>\n@import url('https://fonts.googleapis.com/css2?family=Xanh+Mono&display=swap');\n.open22{\n background-color:rgb(143, 49, 157);\n background-repeat: no-repeat;\n background-position: center;\n width: 100%;\n height:225px;\n padding-top:0px;\n \n \n}\n\np.online{\n font-family: 'Xanh Mono', monospace;\n color: #FFFFFF;\n padding-top:23px;\n font-size: 50px;\n text-align:center;\n}\n</style>\n\n\n<div class=\"open22\">\n<div><p class=\"online\">{{msg.online}}</p></div>\n</div>\n\n","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","x":840,"y":420,"wires":[[]]},{"id":"d8c86af7.92aeb8","type":"ui_group","name":"genel","tab":"c1dcfb03.ffed9","order":1,"disp":false,"width":20,"collapse":false},{"id":"c1dcfb03.ffed9","type":"ui_tab","name":"dash","icon":"dashboard","order":1}]
