GPS Skyplot on dashboard with node template and json
Hello guys!!,
First of all i'm new with html and javascript, i have some experience with c++.
As i said i'm trying to build a gps skyplot on Node-red dashboard for that purpose i took and edit this
html code to get cover about circle's color wich was needed to be by gps constellation. With my edition i got this:
skyplot
<!DOCTYPE html>
<html>
	<head>
		<meta charset='ISO-8859-1'>
		<script src="https://d3js.org/d3.v3.min.js"></script>
	</head>
	<body style='background-color:lightgray'>
		<div id="chart" style='width: 400px; height: 400px; padding-left: 5px; padding-bottom: 5px;'></div>
		<script>
			var deg2rad = Math.PI/180;
            var width = 400, height = 350, radius = Math.min(width, height) / 2 - 30;
            var svg = d3.select("#chart").append("svg")
			    .attr("width", width)
			    .attr("height", height)
			    .append("g")
			    .attr("transform", "translate(" + width / 2 + "," + height / 2 + ")");
            var r = d3.scale.linear()
			    .domain([90, 0])
			    .range([0, radius]);
           var line = d3.svg.line.radial()
			    .radius(function(d) {return r(d[1]);})
			    .angle(function(d) {return -d[0] + Math.PI / 2;});
            var gr = null;
            createSkyplot();
			var json = {"type" : "GSV",
                        "inView" : [{"data" : [1, 45, 90,"#EEE41D"]},
                                    {"data" : [2, 70, 180,"#EEE41D"]},
                                    {"data" : [3, 70, 225,"#EC1C0B"]},
                                    {"data" : [4, 70, 270,"#EC1C0B"]},
                                    {"data" : [5, 70, 315,"#0BA1EC"]},
                                    {"data" : [6, 70, 0,"#0BA1EC"]}]
            updateSkyPlot(json);
            function createSkyplot(){
	            gr = svg.append("g")
				    .attr("class", "r axis")
				    .selectAll("g")
				    .data(r.ticks(5))
				    .enter().append("g");
                gr.append("circle").attr("r", r).style('fill', 'white');
	            gr.append("text")
		            .attr("y", function(d) { return -r(d) - 4; })
		            .attr("transform", "rotate(20)")
		            .style("text-anchor", "middle")
		            .style('fill', 'blue')
    	            .text(function(d) { return d;});
	            var ga = svg.append("g")
				    .attr("class", "a axis")
				    .selectAll("g")
				    .data(d3.range(0, 360, 45))
      			    .attr("transform", function(d) {return "rotate(" + (d - 90) + ")";});
                ga.append("line").attr("x2", radius).style('stroke', 'black').style('stroke-dasharray', '1,8');
	            ga.append("text")
    	            .attr("x", radius + 6)
    	            .attr("dy", ".35em")
    	            .style("text-anchor", function(d) { return d < 360 && d > 90 ? "end" : null; })
		            .attr("transform", function(d) { return d < 360 && d > 90 ? "rotate(180 " + (radius + 3) + ",0)" : null; })
    	            .text(function(d) { return d + "°"; });
function updateSkyPlot(d){
	var pos = [];
	var inview = d.inView;
	for (var elem in inview){
		if (inview.hasOwnProperty(elem)) {
			// the azimuth should be in radians and substracted from (Math.PI/2)	"data" : [1, 45, 90]
			var d = [(Math.PI/2) - inview[elem].data[2]*deg2rad, inview[elem].data[1]];
			pos.push({ "angle": d, "label": inview[elem].data[0] , "col": inview[elem].data[3] });
		.domain([90, 0])
	var color = d3.scale.category20();
	svg.selectAll('circle').remove();
    var points = svg.selectAll("point")
    	.data(pos)
    	.enter()
    	.append("a")
    		var coors = line([d.angle]).slice(1).slice(0, -1);
    		return "translate(" + coors + ")"
    points.append("circle")
    	.attr("class", "point")
      	.attr("r", 8)
        .attr("fill",function(d,i){return color(d.col);});
	points.append("text")
		.text( function(d) { return d.label })
		.attr("transform", "translate(-4,5)")
		</script>
	</body>
</html>
At the above code there are two main functions with are CreateSkyplot() and updateSkyPlot(). These two functions needed to work a json data.
So there is my ask for help, how could i push json data into this code ?, i'been spending a couple days and still didn't make it work.
this is what i actually have on Node-Red.
[{"id":"cd495777.95bf48","type":"ui_template","z":"671b9ab9.9caff4","group":"c90580c4.94fb","name":"","order":1,"width":"0","height":"0","format":"<!DOCTYPE html>\n<html>\n\t<head>\n\t\t<meta charset='ISO-8859-1'>\n\t\t<script src=\"https://d3js.org/d3.v3.min.js\"></script>\n\t</head>\n\n\t<body style='background-color:lightgray'>\n\t\t<div id=\"chart\" style='width: 400px; height: 400px; padding-left: 5px; padding-bottom: 5px;'></div>\n\n\t\t<script>\n\t\t(function(scope) {\n                // watch msg object from Node-RED\n                scope.$watch('msg',function(msg) {\n                    // new message received\n                    var Data=msg.payload;\n                    //window.alert(strlink2);\n                    //document.getElementById(\"refee\").setAttribute(\"href\",strlink2);\n        \t\t\tvar deg2rad = Math.PI/180;\n                    var width = 400, height = 350, radius = Math.min(width, height) / 2 - 30;\n        \n                    var svg = d3.select(\"#chart\").append(\"svg\")\n        \t\t\t    .attr(\"width\", width)\n        \t\t\t    .attr(\"height\", height)\n        \t\t\t    .append(\"g\")\n        \t\t\t    .attr(\"transform\", \"translate(\" + width / 2 + \",\" + height / 2 + \")\");\n        \t\t\t\t  \n                    var r = d3.scale.linear()\n        \t\t\t    .domain([90, 0])\n        \t\t\t    .range([0, radius]);\n          \n                   var line = d3.svg.line.radial()\n        \t\t\t    .radius(function(d) {return r(d[1]);})\n        \t\t\t    .angle(function(d) {return -d[0] + Math.PI / 2;});\n        \n                    var gr = null;\n        \n                    createSkyplot();\n        \n        \t\t\tvar json = {\"type\" : \"GSV\",\n                                \"inView\" : [{\"data\" : [1, 45, 90,\"#69b3a2\"]},\n                                            {\"data\" : [3, 70, 180,\"#69b3a2\"]},\n                                            {\"data\" : [5, 70, 225,\"#A82051\"]},\n                                            {\"data\" : [3, 70, 270,\"#69b3a2\"]},\n                                            {\"data\" : [3, 70, 315,\"#69b3a2\"]},\n                                            {\"data\" : [3, 70, 0,\"#69b3a2\"]}]\n                               };\n                               \n                    //updateSkyPlot(json);\n                    updateSkyPlot(Data);\n        \n                    function createSkyplot(){\t\n        \t            //////////////////////\t\t\t  \n        \t            gr = svg.append(\"g\")\n        \t\t\t\t    .attr(\"class\", \"r axis\")\n        \t\t\t\t    .selectAll(\"g\")\n        \t\t\t\t    .data(r.ticks(5))\n        \t\t\t\t    .enter().append(\"g\");\n        \n                        gr.append(\"circle\").attr(\"r\", r).style('fill', 'white');\n        \n        \t            gr.append(\"text\")\n        \t\t            .attr(\"y\", function(d) { return -r(d) - 4; })\n        \t\t            .attr(\"transform\", \"rotate(20)\")\n        \t\t            .style(\"text-anchor\", \"middle\")\n        \t\t            .style('fill', 'blue')\n            \t            .text(function(d) { return d;});\n        \t            /////////////////////\n        \n        \t            /////////////////////\n        \t            var ga = svg.append(\"g\")\n        \t\t\t\t    .attr(\"class\", \"a axis\")\n        \t\t\t\t    .selectAll(\"g\")\n        \t\t\t\t    .data(d3.range(0, 360, 45))\n        \t\t\t\t    .enter().append(\"g\")\n              \t\t\t    .attr(\"transform\", function(d) {return \"rotate(\" + (d - 90) + \")\";});\n        \n                        ga.append(\"line\").attr(\"x2\", radius).style('stroke', 'black').style('stroke-dasharray', '1,8');\n        \t  \n        \t            ga.append(\"text\")\n            \t            .attr(\"x\", radius + 6)\n            \t            .attr(\"dy\", \".35em\")\n            \t            .style(\"text-anchor\", function(d) { return d < 360 && d > 90 ? \"end\" : null; })\n        \t\t            .attr(\"transform\", function(d) { return d < 360 && d > 90 ? \"rotate(180 \" + (radius + 3) + \",0)\" : null; })\n            \t            .text(function(d) { return d + \"°\"; });\n        \t            /////////////////////\n                        }\n        \n                    function updateSkyPlot(d){\n                    \tvar pos = [];\n                    \tvar inview = d.inView;\n                    \n                    \tfor (var elem in inview){\n                    \t\tif (inview.hasOwnProperty(elem)) {\n                    \t\t\t// the azimuth should be in radians and substracted from (Math.PI/2)\t\"data\" : [1, 45, 90]\n                    \t\t\tvar d = [(Math.PI/2) - inview[elem].data[2]*deg2rad, inview[elem].data[1]]; \n                    \t\t\tpos.push({ \"angle\": d, \"label\": inview[elem].data[0] , \"col\": inview[elem].data[3] });\n                    \t\t}\n                    \t}\n                    \n                    \tvar r = d3.scale.linear()\n                    \t\t.domain([90, 0])\n                    \t\t.range([0, radius]);\n                    \n                    \tvar line = d3.svg.line.radial()\n                    \t\t.radius(function(d) {return r(d[1]);})\n                    \t\t.angle(function(d) {return -d[0] + Math.PI / 2;});\n                    \n                    \tvar color = d3.scale.category20();\n                    \n                    \tsvg.selectAll('circle').remove();\n                    \n                    \tgr.append(\"circle\").attr(\"r\", r).style('fill', 'white');\n                    \n                        var points = svg.selectAll(\"point\")\n                        \t.data(pos)\n                        \t.enter()\n                        \t.append(\"a\")\n                        \t.attr(\"transform\", function(d) {\n                        \t\tvar coors = line([d.angle]).slice(1).slice(0, -1);\n                        \t\treturn \"translate(\" + coors + \")\"\n                        \t});\n                    \n                        points.append(\"circle\")\n                        \t.attr(\"class\", \"point\")\n                          \t.attr(\"r\", 8)\n                            .attr(\"fill\",function(d,i){return color(d.col);});\n                    \n                    \tpoints.append(\"text\")\n                    \t\t.text( function(d) { return d.label })\n                    \t\t.attr(\"transform\", \"translate(-4,5)\")\n                    });\t\n            }\n        })(scope);\n\t\t</script>\n\n\t</body>\n</html>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":400,"y":1880,"wires":[["ea5302c.44631"]]},{"id":"9d15c900.429ef8","type":"inject","z":"671b9ab9.9caff4","name":"JSON2","topic":"","payload":"{\"type\":\"GSV\",\"inView\":[{\"data\":[1,25,90,\"#69b3a2\"]},{\"data\":[2,25,180,\"#69b3a2\"]},{\"data\":[3,25,225,\"#A82051\"]},{\"data\":[4,25,270,\"#69b3a2\"]},{\"data\":[5,25,315,\"#69b3a2\"]},{\"data\":[6,25,0,\"#69b3a2\"]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":1880,"wires":[["cd495777.95bf48"]]},{"id":"ea5302c.44631","type":"debug","z":"671b9ab9.9caff4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":560,"y":1880,"wires":[]},{"id":"c90580c4.94fb","type":"ui_group","z":"","name":"Skyplot","tab":"a624fbe6.d612b8","order":1,"disp":true,"width":"6","collapse":false},{"id":"a624fbe6.d612b8","type":"ui_tab","z":"","name":"GPS","icon":"gps_fixed","order":1,"disabled":false,"hidden":false}]
Thanks for reading and any advice. Regards!!
I got an error (in the browser console) when trying to run your flow. There is a syntax error (unbalanced closing brackets) near the end of the code. After fixing I could get the drawing in the dashboard for both the hard coded json variable as well as for the data injected via msg.payload.
//updateSkyPlot(Data);
Modified flow:
[{"id":"8caf3d00.56893","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"cb6392a.179c97","type":"ui_template","z":"8caf3d00.56893","group":"e7d5b9e4.972fe8","name":"","order":1,"width":"10","height":"12","format":"<!DOCTYPE html>\n<html>\n\n<head>\n    <meta charset='ISO-8859-1'>\n    <script src=\"https://d3js.org/d3.v3.min.js\"></script>\n</head>\n\n<body style='background-color:lightgray'>\n    <div id=\"chart\" style='width: 400px; height: 400px; padding-left: 5px; padding-bottom: 5px;'></div>\n\n    <script>\n        (function (scope) {\n            // watch msg object from Node-RED\n            scope.$watch('msg', function (msg) {\n                // new message received\n                var Data = msg.payload;\n                //window.alert(strlink2);\n                //document.getElementById(\"refee\").setAttribute(\"href\",strlink2);\n                var deg2rad = Math.PI / 180;\n                var width = 400, height = 350, radius = Math.min(width, height) / 2 - 30;\n\n                var svg = d3.select(\"#chart\").append(\"svg\")\n                    .attr(\"width\", width)\n                    .attr(\"height\", height)\n                    .append(\"g\")\n                    .attr(\"transform\", \"translate(\" + width / 2 + \",\" + height / 2 + \")\");\n\n                var r = d3.scale.linear()\n                    .domain([90, 0])\n                    .range([0, radius]);\n\n                var line = d3.svg.line.radial()\n                    .radius(function (d) { return r(d[1]); })\n                    .angle(function (d) { return -d[0] + Math.PI / 2; });\n\n                var gr = null;\n\n                createSkyplot();\n\n                var json = {\n                    \"type\": \"GSV\",\n                    \"inView\": [{ \"data\": [1, 45, 90, \"#69b3a2\"] },\n                    { \"data\": [3, 70, 180, \"#69b3a2\"] },\n                    { \"data\": [5, 70, 225, \"#A82051\"] },\n                    { \"data\": [3, 70, 270, \"#69b3a2\"] },\n                    { \"data\": [3, 70, 315, \"#69b3a2\"] },\n                    { \"data\": [3, 70, 0, \"#69b3a2\"] }]\n                };\n\n                //updateSkyPlot(json);\n                updateSkyPlot(Data);\n\n                function createSkyplot() {\n                    //////////////////////\t\t\t  \n                    gr = svg.append(\"g\")\n                        .attr(\"class\", \"r axis\")\n                        .selectAll(\"g\")\n                        .data(r.ticks(5))\n                        .enter().append(\"g\");\n\n                    gr.append(\"circle\").attr(\"r\", r).style('fill', 'white');\n\n                    gr.append(\"text\")\n                        .attr(\"y\", function (d) { return -r(d) - 4; })\n                        .attr(\"transform\", \"rotate(20)\")\n                        .style(\"text-anchor\", \"middle\")\n                        .style('fill', 'blue')\n                        .text(function (d) { return d; });\n                    /////////////////////\n\n                    /////////////////////\n                    var ga = svg.append(\"g\")\n                        .attr(\"class\", \"a axis\")\n                        .selectAll(\"g\")\n                        .data(d3.range(0, 360, 45))\n                        .enter().append(\"g\")\n                        .attr(\"transform\", function (d) { return \"rotate(\" + (d - 90) + \")\"; });\n\n                    ga.append(\"line\").attr(\"x2\", radius).style('stroke', 'black').style('stroke-dasharray', '1,8');\n\n                    ga.append(\"text\")\n                        .attr(\"x\", radius + 6)\n                        .attr(\"dy\", \".35em\")\n                        .style(\"text-anchor\", function (d) { return d < 360 && d > 90 ? \"end\" : null; })\n                        .attr(\"transform\", function (d) { return d < 360 && d > 90 ? \"rotate(180 \" + (radius + 3) + \",0)\" : null; })\n                        .text(function (d) { return d + \"°\"; });\n                    /////////////////////\n                }\n\n                function updateSkyPlot(d) {\n                    var pos = [];\n                    var inview = d.inView;\n\n                    for (var elem in inview) {\n                        if (inview.hasOwnProperty(elem)) {\n                            // the azimuth should be in radians and substracted from (Math.PI/2)\t\"data\" : [1, 45, 90]\n                            var d = [(Math.PI / 2) - inview[elem].data[2] * deg2rad, inview[elem].data[1]];\n                            pos.push({ \"angle\": d, \"label\": inview[elem].data[0], \"col\": inview[elem].data[3] });\n                        }\n                    }\n\n                    var r = d3.scale.linear()\n                        .domain([90, 0])\n                        .range([0, radius]);\n\n                    var line = d3.svg.line.radial()\n                        .radius(function (d) { return r(d[1]); })\n                        .angle(function (d) { return -d[0] + Math.PI / 2; });\n\n                    var color = d3.scale.category20();\n\n                    svg.selectAll('circle').remove();\n\n                    gr.append(\"circle\").attr(\"r\", r).style('fill', 'white');\n\n                    var points = svg.selectAll(\"point\")\n                        .data(pos)\n                        .enter()\n                        .append(\"a\")\n                        .attr(\"transform\", function (d) {\n                            var coors = line([d.angle]).slice(1).slice(0, -1);\n                            return \"translate(\" + coors + \")\"\n                        });\n\n                    points.append(\"circle\")\n                        .attr(\"class\", \"point\")\n                        .attr(\"r\", 8)\n                        .attr(\"fill\", function (d, i) { return color(d.col); });\n\n                    points.append(\"text\")\n                        .text(function (d) { return d.label })\n                        .attr(\"transform\", \"translate(-4,5)\")\n                }\n            })\n        }) (scope);\n    </script>\n\n</body>\n\n</html>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":400,"y":180,"wires":[["91242dc3.e1365"]]},{"id":"7c2b01f8.e85d4","type":"inject","z":"8caf3d00.56893","name":"JSON2","props":[{"p":"payload","v":"{\"type\":\"GSV\",\"inView\":[{\"data\":[1,25,90,\"#69b3a2\"]},{\"data\":[2,25,180,\"#69b3a2\"]},{\"data\":[3,25,225,\"#A82051\"]},{\"data\":[4,25,270,\"#69b3a2\"]},{\"data\":[5,25,315,\"#69b3a2\"]},{\"data\":[6,25,0,\"#69b3a2\"]}]}","vt":"json"},{"p":"topic","v":"","vt":"string"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"type\":\"GSV\",\"inView\":[{\"data\":[1,25,90,\"#69b3a2\"]},{\"data\":[2,25,180,\"#69b3a2\"]},{\"data\":[3,25,225,\"#A82051\"]},{\"data\":[4,25,270,\"#69b3a2\"]},{\"data\":[5,25,315,\"#69b3a2\"]},{\"data\":[6,25,0,\"#69b3a2\"]}]}","payloadType":"json","x":210,"y":180,"wires":[["cb6392a.179c97"]]},{"id":"91242dc3.e1365","type":"debug","z":"8caf3d00.56893","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":560,"y":180,"wires":[]},{"id":"e7d5b9e4.972fe8","type":"ui_group","z":"","name":"Skyplot","tab":"148b6089.d57b1f","order":1,"disp":true,"width":"10","collapse":false},{"id":"148b6089.d57b1f","type":"ui_tab","z":"","name":"GPS","icon":"gps_fixed","order":1,"disabled":false,"hidden":false}]
Andrei, Thanks for you reply and fixing my brackets, i didn't notice about it. After run this code there is a little trouble, this nodes inject a skyplot on every msg.paylaoad, what could i change to just update the one already shown?, as far as i understand with this code it's already updating any skyplot.
I've just made the final solution. Here's the flow. Andrei, Thanks again for your help. Regards!
[{"id":"24a9e9b4.730fe6","type":"ui_template","z":"97fc7bbb.f970d8","group":"d02c68f8.1ad438","name":"","order":1,"width":"10","height":"12","format":"<!DOCTYPE html>\n<html>\n\n<head>\n    <meta charset='ISO-8859-1'>\n    <script src=\"https://d3js.org/d3.v3.min.js\"></script>\n</head>\n\n<body style='background-color:lightgray'>\n    <div id=\"chart\" style='width: 400px; height: 400px; padding-left: 5px; padding-bottom: 5px;'></div>\n\n    <script>\n        var deg2rad = Math.PI / 180;\n        var width = 400, height = 350, radius = Math.min(width, height) / 2 - 30;\n\n        var svg = d3.select(\"#chart\").append(\"svg\")\n            .attr(\"width\", width)\n            .attr(\"height\", height)\n            .append(\"g\")\n            .attr(\"transform\", \"translate(\" + width / 2 + \",\" + height / 2 + \")\");\n\n        var r = d3.scale.linear()\n            .domain([90, 0])\n            .range([0, radius]);\n\n        var line = d3.svg.line.radial()\n            .radius(function (d) { return r(d[1]); })\n            .angle(function (d) { return -d[0] + Math.PI / 2; });\n\n        var gr = null;\n        \n        createSkyplot();\n        \n        function createSkyplot() {\n        //////////////////////\t\t\t  \n        gr = svg.append(\"g\")\n            .attr(\"class\", \"r axis\")\n            .selectAll(\"g\")\n            .data(r.ticks(5))\n            .enter().append(\"g\");\n\n        gr.append(\"circle\").attr(\"r\", r).style('fill', 'white');\n\n        gr.append(\"text\")\n            .attr(\"y\", function (d) { return -r(d) - 4; })\n            .attr(\"transform\", \"rotate(20)\")\n            .style(\"text-anchor\", \"middle\")\n            .style('fill', 'blue')\n            .text(function (d) { return d; });\n        /////////////////////\n\n        /////////////////////\n        var ga = svg.append(\"g\")\n            .attr(\"class\", \"a axis\")\n            .selectAll(\"g\")\n            .data(d3.range(0, 360, 45))\n            .enter().append(\"g\")\n            .attr(\"transform\", function (d) { return \"rotate(\" + (d - 90) + \")\"; });\n\n        ga.append(\"line\").attr(\"x2\", radius).style('stroke', 'black').style('stroke-dasharray', '1,8');\n\n        ga.append(\"text\")\n            .attr(\"x\", radius + 6)\n            .attr(\"dy\", \".35em\")\n            .style(\"text-anchor\", function (d) { return d < 360 && d > 90 ? \"end\" : null; })\n            .attr(\"transform\", function (d) { return d < 360 && d > 90 ? \"rotate(180 \" + (radius + 3) + \",0)\" : null; })\n            .text(function (d) { return d + \"°\"; });\n        /////////////////////\n    }\n    \n        \n        (function ($scope) {\n            // watch msg object from Node-RED\n            scope.$watch('msg', function (msg) {\n                \n                svg.selectAll('circle').remove();\n                svg.selectAll('text').remove();\n                \n                createSkyplot();\n        \n                function createSkyplot() {\n                //////////////////////\t\t\t  \n                gr = svg.append(\"g\")\n                    .attr(\"class\", \"r axis\")\n                    .selectAll(\"g\")\n                    .data(r.ticks(5))\n                    .enter().append(\"g\");\n        \n                gr.append(\"circle\").attr(\"r\", r).style('fill', 'white');\n        \n                gr.append(\"text\")\n                    .attr(\"y\", function (d) { return -r(d) - 4; })\n                    .attr(\"transform\", \"rotate(20)\")\n                    .style(\"text-anchor\", \"middle\")\n                    .style('fill', 'blue')\n                    .text(function (d) { return d; });\n                /////////////////////\n        \n                /////////////////////\n                var ga = svg.append(\"g\")\n                    .attr(\"class\", \"a axis\")\n                    .selectAll(\"g\")\n                    .data(d3.range(0, 360, 45))\n                    .enter().append(\"g\")\n                    .attr(\"transform\", function (d) { return \"rotate(\" + (d - 90) + \")\"; });\n        \n                ga.append(\"line\").attr(\"x2\", radius).style('stroke', 'black').style('stroke-dasharray', '1,8');\n        \n                ga.append(\"text\")\n                    .attr(\"x\", radius + 6)\n                    .attr(\"dy\", \".35em\")\n                    .style(\"text-anchor\", function (d) { return d < 360 && d > 90 ? \"end\" : null; })\n                    .attr(\"transform\", function (d) { return d < 360 && d > 90 ? \"rotate(180 \" + (radius + 3) + \",0)\" : null; })\n                    .text(function (d) { return d + \"°\"; });\n                /////////////////////\n            }\n                \n                \n                \n                // new message received\n                var Data = msg.payload;\n                //window.alert(strlink2);\n                //document.getElementById(\"refee\").setAttribute(\"href\",strlink2);\n                var json = {\n                    \"type\": \"GSV\",\n                    \"inView\": [{ \"data\": [1, 45, 90, \"#69b3a2\"] },\n                    { \"data\": [3, 70, 180, \"#69b3a2\"] },\n                    { \"data\": [5, 70, 225, \"#A82051\"] },\n                    { \"data\": [3, 70, 270, \"#69b3a2\"] },\n                    { \"data\": [3, 70, 315, \"#69b3a2\"] },\n                    { \"data\": [3, 70, 0, \"#69b3a2\"] }]\n                };\n\n                //updateSkyPlot(json);\n                updateSkyPlot(Data);\n                \n                \n                \n                \n                \n                function updateSkyPlot(d) {\n                    \n                    \n                    \n                    \n                    var pos = [];\n                    var inview = d.inView;\n\n                    for (var elem in inview) {\n                        if (inview.hasOwnProperty(elem)) {\n                            // the azimuth should be in radians and substracted from (Math.PI/2)\t\"data\" : [1, 45, 90]\n                            var d = [(Math.PI / 2) - inview[elem].data[2] * deg2rad, inview[elem].data[1]];\n                            pos.push({ \"angle\": d, \"label\": inview[elem].data[0], \"col\": inview[elem].data[3] });\n                        }\n                    }\n\n                    var r = d3.scale.linear()\n                        .domain([90, 0])\n                        .range([0, radius]);\n\n                    var line = d3.svg.line.radial()\n                        .radius(function (d) { return r(d[1]); })\n                        .angle(function (d) { return -d[0] + Math.PI / 2; });\n\n                    var color = d3.scale.category20();\n\n                    svg.selectAll('circle').remove();\n                    \n\n                    gr.append(\"circle\").attr(\"r\", r).style('fill', 'white');\n\n                    var points = svg.selectAll(\"point\")\n                        .data(pos)\n                        .enter()\n                        .append(\"a\")\n                        .attr(\"transform\", function (d) {\n                            var coors = line([d.angle]).slice(1).slice(0, -1);\n                            return \"translate(\" + coors + \")\"\n                        });\n\n                    points.append(\"circle\")\n                        .attr(\"class\", \"point\")\n                        .attr(\"r\", 8)\n                        .attr(\"fill\", function (d, i) { return color(d.col); });\n\n                    points.append(\"text\")\n                        .text(function (d) { return d.label })\n                        .attr(\"transform\", \"translate(-4,5)\")\n                }\n            })\n        }) (scope);\n    </script>\n</body>\n</html>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":420,"y":220,"wires":[["e1b9877f.1c3e38"]]},{"id":"7a6eba55.43bec4","type":"inject","z":"97fc7bbb.f970d8","name":"JSON2","topic":"","payload":"{\"type\":\"GSV\",\"inView\":[{\"data\":[5,25,90,\"#00FF00\"]},{\"data\":[5,25,180,\"#0000FF\"]},{\"data\":[5,25,225,\"#FF0000\"]},{\"data\":[5,25,270,\"#FFFF00\"]},{\"data\":[5,25,315,\"#00FFFF\"]},{\"data\":[5,25,0,\"#FF00FF\"]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":220,"wires":[["24a9e9b4.730fe6"]]},{"id":"e1b9877f.1c3e38","type":"debug","z":"97fc7bbb.f970d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":630,"y":220,"wires":[]},{"id":"e2f9fd7e.c4e17","type":"inject","z":"97fc7bbb.f970d8","name":"JSON2","topic":"","payload":"{\"type\":\"GSV\",\"inView\":[{\"data\":[5,70,90,\"#69b3a2\"]},{\"data\":[5,70,180,\"#69b3a2\"]},{\"data\":[5,70,225,\"#A82051\"]},{\"data\":[5,70,270,\"#69b3a2\"]},{\"data\":[5,70,315,\"#69b3a2\"]},{\"data\":[5,70,0,\"#69b3a2\"]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":260,"wires":[["24a9e9b4.730fe6"]]},{"id":"5f3a5195.eb244","type":"inject","z":"97fc7bbb.f970d8","name":"JSON2","topic":"","payload":"{\"type\":\"GSV\",\"inView\":[{\"data\":[0,50,90,\"#69b3a2\"]},{\"data\":[0,50,180,\"#69b3a2\"]},{\"data\":[0,50,225,\"#A82051\"]},{\"data\":[0,50,270,\"#69b3a2\"]},{\"data\":[0,50,315,\"#69b3a2\"]},{\"data\":[0,50,0,\"#69b3a2\"]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":300,"wires":[["24a9e9b4.730fe6"]]},{"id":"d02c68f8.1ad438","type":"ui_group","z":"","name":"Skyplot 2","tab":"f1e6af6c.7b594","order":1,"disp":true,"width":"10","collapse":false},{"id":"f1e6af6c.7b594","type":"ui_tab","z":"","name":"GPS","icon":"gps_fixed","order":1,"disabled":false,"hidden":false}]
