Hi, is there a possibility to change the spacing between the group name (if showed) and the rest of the gorup?
- Use a browers development tool to examine the dashboard page.
- Find the element that displays the group name.
- Look at it's CSS and change it's margin bottom to what you want.
- Put the appropriate
CSS selectorto identify the elment and add theCSS rulefor the value you want in a ui-template wrapped in a ... block. - deploy and go look at it.
if you want to see a working example using the ui_template, go look in the Share Your Projects forum for the Coffee Pot Timer thread
Thanks - I see. The min height is 31px what is high.
In the meantime I found another solution: Hiding group name and use a formatted text field at top.
