Hi all
I've buillt a small rqlite cluster (3 nodes) and I would like to use the sqlite node to connect to it.
Since this database is a distant one (I.e. not running in the same server where node-red runs) and provides HA, how can I fill in the "Database name" field of the sqlite node in node-RED?
Something like this, ipaddress, path and filename.
192.168.1.127/home/pi/dbs/joshuadata.sqlite
I'd be interested in this - is there any more info ? Like which server (rqlite or dqlite) are you actually using ? I thought you had to use http to access rqlite ?
Ho wow thanks! I didn't know it would be that simple.
Are you using rqlite or dqlite with node-red ?
Small up
is it better to use a MySQL high availability cluster with my-SQL node instead?
Or... can we use rqlite with http node instead ?
@dceejay if you are interested,
I created flows to use RQLite with Node-RED, with HTTP nodes + HTTP 301 redirect support.
