Harmony websocket crashing node-red
Been using "node-red-contrib-harmony-websocket" for years. Today it caused node-red crash while in use. When I tried to restart node-red this error in the log...
$ Start Node-RED
Once Node-RED has started, point a browser at http://192.168.1.4:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-start to start Node-RED again
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
nodered.service: Referenced but unset environment variable evaluates to an empty string: NODE_RED_OPTIONS
18 Jun 23:41:32 - [info]
Welcome to Node-RED
18 Jun 23:41:32 - [info] Node-RED version: v4.0.9
18 Jun 23:41:32 - [info] Node.js version: v20.19.2
18 Jun 23:41:32 - [info] Linux 6.8.0-60-generic x64 LE
18 Jun 23:41:32 - [info] Loading palette nodes
18 Jun 23:41:33 - [info] node-red-contrib-shelly version: v11.6.1
18 Jun 23:41:33 - [info] Dashboard version 3.6.5 started at /ui
18 Jun 23:41:33 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
18 Jun 23:41:34 - [info] Settings file : /home/mark/.node-red/settings.js
18 Jun 23:41:34 - [info] Context store : 'default' [module=memory]
18 Jun 23:41:34 - [info] User directory : /home/mark/.node-red
18 Jun 23:41:34 - [warn] Projects disabled : editorTheme.projects.enabled=false
18 Jun 23:41:34 - [info] Flows file : /home/mark/.node-red/flows.json
18 Jun 23:41:34 - [info] Server now running at http://127.0.0.1:1880/
18 Jun 23:41:34 - [warn] Using unencrypted credentials
18 Jun 23:41:34 - [info] Starting flows
18 Jun 23:41:34 - [error] [e-mail:xxxxxxxxxx@vtext.com] No e-mail userid set
18 Jun 23:41:34 - [info] Started flows
Shelly gen2 server is listening on port 10001
18 Jun 23:41:34 - [info] [mqtt-broker:MQTT] Connected to broker: mqtt://192.168.1.4:1883
18 Jun 23:41:34 - [red] Uncaught Exception:
18 Jun 23:41:34 - [error] TypeError: Cannot read properties of null (reading 'open') at Harmony.sendCommand (/home/mark/.node-red/node_modules/harmony-websocket/lib/harmony-websocket.js:411:29)
at /home/mark/.node-red/node_modules/bad-node-red-contrib-harmony-websocket/lib/hub.js:258:46
at processTicksAndRejections (node:internal/process/task_queues:95:5)
at runNextTicks (node:internal/process/task_queues:64:3)
at processImmediate (node:internal/timers:454:9)
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Failed with result 'exit-code'.
nodered.service: Consumed 3.899s CPU time.
No idea why this is happening now,,,,,
At this point I need some advice how to get back into node-red to understand why Harmony node is causing the crash...
The Harmony hub is working fine I can access the it via Logitech app on my phone....
Read this from the node's Github issues page .. seems related
You can start Node-red in "safe mode" with node-red --safe
Your flows don't run but the editor is available, so hopefully you can investigate or delete any nodes causing a crash.
A deploy then restarts Node-red normally.
Thank you that allow me to get back in. Now to understand why harmony nodes causing the crash
First thanks "node-red --safe" which has help in working this problem. I thought I had correct issue by removing all flows using the "node-red-contrib-harmony-websocket" Then removing/reinstalling "node-red-contrib-harmony-websocket", Then importing the flows and redeploying. Things have been fine for 5 days then again the issues has occurred.
After some days of watching the node-red logs I captured the following.. (see log attached below.) concerning "HarmonyWS" closing and opening, finally closing at HarmonyWS at 14:18:55... Node red then crashed at 14:23:36, that is when I request HarmonyWS to switch the on stereo.
After that the log contains cycling of node-red restarts and crashs. The only fix I have found is again remove flows using HarmonyWS, then remove/reinstall "node-red-contrib-harmony-websocket"...
As before the Harmony Hub is online, and the Harmony app on my phone can access the hub and control all devices.
Again at a point on how to precede in trouble shooting this issue.
mark@OptiPlex9020M:/var/log/mosquitto$ node-red-log
26 Jun 04:12:31 - [info] Node-RED version: v4.0.9
26 Jun 04:12:31 - [info] Node.js  version: v20.19.2
26 Jun 04:12:31 - [info] Linux 6.8.0-60-generic x64 LE
26 Jun 04:12:31 - [info] Loading palette nodes
26 Jun 04:12:33 - [info] node-red-contrib-shelly version: v11.6.1
26 Jun 04:12:34 - [info] Dashboard version 3.6.5 started at /ui
26 Jun 04:12:34 - [info] Settings file  : /home/mark/.node-red/settings.js
26 Jun 04:12:34 - [info] Context store  : 'default' [module=memory]
26 Jun 04:12:34 - [info] User directory : /home/mark/.node-red
26 Jun 04:12:34 - [warn] Projects disabled : editorTheme.projects.enabled=false
26 Jun 04:12:34 - [info] Flows file     : /home/mark/.node-red/flows.json
26 Jun 04:12:34 - [info] Server now running at http://127.0.0.1:1880/
26 Jun 04:12:34 - [warn] Using unencrypted credentials
26 Jun 04:12:35 - [info] Starting flows
26 Jun 04:12:35 - [error] [e-mail:xxxxxxxxxxxx] No e-mail userid set
26 Jun 04:12:35 - [info] Started flows
26 Jun 04:12:35 - [info] [mqtt-broker:MQTT] Connection failed to broker: mqtt://192.168.1.4:1883
26 Jun 04:12:35 - [info] HarmonyWS open (192.168.1.244)
26 Jun 04:12:50 - [info] [mqtt-broker:MQTT] Connected to broker: mqtt://192.168.1.4:1883
26 Jun 02:27:07 - [info] HarmonyWS close (192.168.1.244)
26 Jun 02:27:07 - [info] HarmonyWS open (192.168.1.244)
26 Jun 08:17:49 - [error] [http request:GEt Venstar status] RequestError: connect EHOSTUNREACH 192.168.1.245:80
26 Jun 12:50:15 - [info] HarmonyWS close (192.168.1.244)
26 Jun 12:50:15 - [info] HarmonyWS open (192.168.1.244)
26 Jun 14:15:25 - [info] HarmonyWS close (192.168.1.244)
26 Jun 14:15:25 - [info] HarmonyWS open (192.168.1.244)
26 Jun 14:15:56 - [warn] [shelly-gen2:e938fd258c4f87a6] Error in executeCommand2: /rpc/Shelly.GetStatus  --> Error: getaddrinfo ENOTFOUND shellyplus1-b8d61a8a8b48.local
26 Jun 14:18:51 - [warn] [shelly-gen2:d3d9917014d7dbc7] Error in executeCommand2: /rpc/Shelly.GetStatus  --> AxiosError: timeout of 5022ms exceeded
26 Jun 14:18:55 - [info] HarmonyWS close (192.168.1.244)
26 Jun 14:23:36 - [red] Uncaught Exception:
26 Jun 14:23:36 - [error] TypeError: Cannot read properties of null (reading 'open')
    at /home/mark/.node-red/node_modules/node-red-contrib-harmony-websocket/lib/hub.js:258:46
There is an open issue from 2023: crashed node-red · Issue #27 · lopelex/node-red-contrib-harmony · GitHub
I don't hood much faith in it being fixed any time soon. You could try adding a me too to see if the owner responds?
Looking at the output, it is not just the harmony websocket, but the mqtt broker, 'shelly-gen2', 'GEt Venstar status' all fail, do you have network connectivity ?
Yes, I know they all show a failure. During my testing I have found that as soon as flows using "HarmonyWS " are removed, these he other failures stopped. I will be watching the logs the next few days to see if these errors reoccur
