Sorry if this isn't the correct place to post this.
Can anyone tell me what is going on in the error log below? This just recently started happening and I uninstall/reinstall node-red and add my flows back one at a time. So far, I can't pin it on any one flow/node, but I'm leaning towards node-red-contrib-alexa-remote2, but I've had it installed and working for months, maybe a year.
Any help would be much appreciated!
29 Sep 10:10:06 - [info] [server:Home Assistant-Mine] Connected to http://supervisor/core
29 Sep 10:10:07 - [red] Uncaught Exception:
29 Sep 10:10:07 - [error] Error: Invalid context key
    at Object.value (/opt/node_modules/@node-red/runtime/lib/nodes/context/index.js:291:31)
    at NodeRedContext.get (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/common/NodeRedContext.js:17:24)
    at EventsState.getComparatorResult (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/BaseNode.js:151:35)
    at EventsState.onHaEventsStateChanged (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/events-state/controller.js:71:32)
    at EventsState.onStatesLoaded (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/events-state/controller.js:179:18)
    at EventEmitter.emit (node:events:539:35)
    at /opt/node_modules/node-red-contrib-home-assistant-websocket/dist/homeAssistant/Websocket.js:230:27
    at runMicrotasks (<anonymous>)
    at processTicksAndRejections (node:internal/process/task_queues:96:5)
2022/09/29 10:10:07 [error] 369#369: *486 recv() failed (104: Connection reset by peer) while reading response header from upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /icons/node-red-contrib-home-assistant-websocket/ha-events-state-changed.svg HTTP/1.1", upstream: "http://127.0.0.1:46836/icons/node-red-contrib-home-assistant-websocket/ha-events-state-changed.svg", host: "qobh7***ed.ui.nabu.casa", referrer: "https://qobh7***ed.ui.nabu.casa/api/hassio_ingress/cdNAdzVXI0tOE-***yMVO4TaE/"
2022/09/29 10:10:07 [error] 369#369: *486 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /icons/node-red/timer.svg HTTP/1.1", upstream: "http://127.0.0.1:46836/icons/node-red/timer.svg", host: "qobh7***ed.ui.nabu.casa", referrer: "https://qobh7***ed.ui.nabu.casa/api/hassio_ingress/cdNAdzVXI0tOE-P2n***4TaE/"
2022/09/29 10:10:07 [error] 369#369: *486 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /icons/node-red-contrib-home-assistant-websocket/ha-current-state.svg HTTP/1.1", upstream: "http://127.0.0.1:46836/icons/node-red-contrib-home-assistant-websocket/ha-current-state.svg", host: "qobh7***ed.ui.nabu.casa", referrer: "https://qobh7***ed.ui.nabu.casa/api/hassio_ingress/cdNAdzV***aEKyMVO4TaE/"
2022/09/29 10:10:07 [error] 369#369: *486 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /icons/node-red/swap.svg HTTP/1.1", upstream: "http://127.0.0.1:46836/icons/node-red/swap.svg", host: "qobh7***ed.ui.nabu.casa", referrer: "https://qobh7***ed.ui.nabu.casa/api/hassio_ingress/cdNAdzV***cyaEKyMVO4TaE/"
[10:10:07] WARNING: Node-RED crashed, halting add-on
