Home Assistant node red add on websocket errors
I have a problem on HA 0.106.2 and have had it for the last couple of updates.
Node red add on version 6.1.3, but has been ongoing for a few versions now, since I reinstalled and setup Home Assistant over my old hassbian set-up a few weeks ago.
I am running home assistant on a pi3b+ with official power supply, installed and boot from ssd.
This is stopping alexa from being able to control lights etc and causing lag generally in the system.
Logger: alexapy.alexawebsocket
First occured: 4:07:31 PM (28 occurences)
Last logged: 6:32:30 PM
WebSocket Error: <class 'concurrent.futures._base.TimeoutError'>
I am also getting this error repeatedly as well:
First occured: 4:44:04 PM (5 occurences)
Last logged: 7:06:34 PM
WebSocket Error: <class 'aiohttp.streams.EofStream'>
I stopped the node red add-on and haven’t had any error messages for the last 5 hours or so.
alexapy.websocket errors continue repeating and building up in the logs and the whole system becoming laggy and sometimes crashing.
The only flow I have in node red is one switch and one script connected to alexa.
I think you stand a better chance of getting a reply if you post your question in the Home Assistant community forum. That's where the author of node-red-contrib-home-assistant-websocket posted the module and answers questions:
Thank you
