Node Red won't start issue with home-assistant websocket
Running (or trying to) Node Red version v1.1.2, node JS v 12.18.3, RPI 3+ home-assistant (Hassio) 0.113.3 on Tinkerboard
Log is;
(node:12484) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'isConnected' of undefined
at TriggerState.get isIntegrationLoaded [as isIntegrationLoaded] (/home/pi/.node-red/node_modules/node-red-contrib-home-assistant-websocket/lib/base-node.js:270:34)
at TriggerState.init (/home/pi/.node-red/node_modules/node-red-contrib-home-assistant-websocket/lib/events-ha-node.js:43:18)
(node:12484) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 23)
I have tried the CLI flag suggested after node-red-start (not sure if that's right) but it hasn't work.
Any assistance would be greatly appreciated.
Thanks in advance
Glenn
The CLI flag is for node itself so the message is a bit misleading. With luck someone here can help but I'd suggest reporting this as an issue at https://github.com/zachowj/node-red-contrib-home-assistant-websocket or asking in the Home Assistant forum.
Yep definitely raise it in the 3rd party forum on the HA forum - the author has a long thread and is very responsive.
Have you installed this to a standalone NR installation - or the integrated one with HACS ?
Craig
Thank you both,
I will take it up on Github.
There seems to be similar issues which I haven't looked into in great detail.
It's standalone, hence the websocket version.
Glenn
