HASSIO to multiple instances of NodeRed?
I've got HASSIO installed on a Pi 3+ with the NodeRed integration running.
NodeRed frequently disconnects with an NGinx warning.
Thinking that it's all a bit too much for the Pi3+ (I've a lot of devices and integrations in HASSIO, the CPU is often at 100% and the memory usage hovers at about 90%)
I've got an instance of NodeRed running on a spare Pi4 but can't get it to talk to the Pi 3+.
The idea was to take NodeRed of the HASSIO device to reduce the workload for the Pi3.
Is there a restriction in HASSIO that will only allow it to talk to one instance of NodeRed at a time?
If so, should I remove NodeRed from HASSIO before attempting to sign up the Pi4 instance?
hopefully someone familiar with Hassio will be here - but it may be easier to ask over in a Hassio forum.
Will do, thanks
