Help! Dynamically create menu from an array
Hello!
I wonder if it's possible to dynamically create menu from an array:
I wrote the following code, obviously it doesn't work:
let menuArray = msg.buildings;
for (let i = 0; i < menuArray.length; i++) {
var menu = [
        "type": 1,
        "components": [
                "type": 3,
                "custom_id": "class_select_1",
                 "options": [
                        "label": `${menuArray[i].name}`,
                        "value": `${menuArray[i].id}`,
                "placeholder": "Choose building",
                "min_values": 1,
                "max_values": 1
There are many ways to do this
But first you need to show us the input object and then an example of what the output would be for the input object.
What you have shown is to vague.
do you want an array of objects in options array or should the menu array be an array of objects.
If first this may help, but if not please supply an input and expected output
const menu = [
        "type": 1,
        "components": [
                "type": 3,
                 "options": [
                "min_values": 1,
                "max_values": 1
    let obj = {
        "option": menuArray[i].name,
        "value": menuArray[i].id
    menu[0].components[0].options.push(obj);
[edit] fixed typo
Thanks for help.
Yea, I want an array of objects in options array. Options should be formed from the array that is formed dynamically.
I've just test your code and got "TypeError: Cannot read properties of undefined (reading '0')"
Input
let newMessage = {};
newMessage.channel = msg.payload.channelId;
newMessage.payload = `<@!${msg.payload.user.id}> "Select building"` ;
newMessage.message = msg.payload.replyMessage.id;
newMessage.embed = {
    "title": `BUILDING MENU`,
    "fields": [
            "name": `Main resources you have 🌿`,
            "value": `šŸ— ${msg.payload.graphql.users[0].food}`
const menu = [
        "type": 1,
        "components": [
                "type": 3,
                "options": [
                "min_values": 1,
                "max_values": 1
    let obj = {
        "option": `${menuArray[i].name}`,
    menu.components[0].options.push(obj);
newMessage.components = menu;
return newMessage;
Expected output:
var ok = [
        "type": 1,
        "components": [
                "type": 3,
                "options": [
                        "label": `Building 1`,
                        "value": `1`,
                       "label": `Building 2`,
                        "value": `2`,
                        "label": `Building 3`,
                        "value": `3`,
                        "label": `Building .......and so on`,
                        "value": `......`,
                "min_values": 1,
                "max_values": 1
Again you provide no input.
Typo
Thanks, appreciate your help :slight_smile: . It works!
