Help in Function Node - Applying different css class based on contents (start letter)
Continuing the discussion from Help in Function Node - Dynamic Table properties (CSV to HTML):
Hi, @bakman2 You were helpful in getting me going in this topic. it is working fine
now, it is required to apply another class similarly based on the solution given, but i tried many things it is not worknig out.
my input when it starts with 'SUM' it is applying a particular css, now in ADDITION to that, if the input starts with 'OEE' i need it to be a different class. would you please help.
your original code is here
let html = ""
html += "<!doctype html><html lang='en'>"
html += "<style>body{font-family:arial;}.running{background:#22c55e;color:#fff;}.not-running{background:#ef4444;color:#fff;}table{border-collapse:collapse}td,th{border:1px solid #999;padding:4px;font-size:12px;}</style>"
html += `<h3>Online Downtime Report (Hosur) for the date ${msg.ddate}</h3>`
html += "<table>"
html += "<thead><tr><th>Machine</th><th>Time-From</th><th>Time-To</th><th>Duration</th><th>Reason 1</th><th>Reason 2</th></tr></thead>"
html += "<tbody>"
msg.payload.forEach((part) => {
    if (part.col2 === undefined) {
        const css_class = part.col1.match("not running")  ? "not-running" : 'running'
        html += `<tr><td colspan='6' class='${css_class}'>${part.col1}</td></tr>`
    } else if (part.col1 !== 'Machine') {
        const machine = msg.payload.filter(x=>x.col1.startsWith("SUM")).find(x=>x.col1.match(".*"+part.col1+".*"))
        let css_class = "running"
        if (machine && machine.col1.match('not running') ){
            css_class = "not-running"
        html += `<tr class="${css_class}"><td>${part.col1}</td><td>${part.col2}</td><td>${part.col3}</td><td>${part.col4}</td><td>${part.col5}</td><td>${part.col6}</td></tr>`
html += "</tbody></table></html>"
msg.payload = html
return msg
