!HELP! node-red-contrib-raumfeld !HELP!
Hi all,
is there anyone who wants to present me a simple flow to control my Teufel ONE M Wi-Fi speaker using Node-RED on a Raspberry Pi 2b?
Unfortunately I cannot find any examples, usable for me, in this forum or elsewhere where node-red-contrib-raumfeld is used. And currently I do not have enough time to read all the hints hidden in any forums...
What I want to do with this flow is:
  • Switch On/Off or at least Mute/Unmute the speaker using an Node-Red dashboard
  • Select on of the 3 Station Buttons using the same dashboard
That's all!
Kind regards
Thomas
Have looked to see if there is an example flow ?
Click on the burger icon and select import, then click on examples and look for node-red-contrib-raumfeld.
@Sean-McG Good hint, thank you! I did not know this function. But for node-red-contrib-raumfeld there are no examples.
:sleepy:
I take it that the node has already been installed ?
If so and there is no example, then I would contact the author and ask for the example flow shown on the nodes page.
Yes it is installed...
And yes, there is an e-mail address on github. May be I will try to do this...
Thank you.
