Hi there,
I am trying to read data from a INA3221 sensor and send to Homeassistant via MQTT.
What are my options here as I only see drivers for the INA219 etc but cant see anything for the INA3221.
I did however find this,
Thanks for any help!
Hi there,
You could try installing direct from github
https://github.com/easybotics/node-red-contrib-easybotics-ina3221
NOTE: If you are running node-red as a HA plugin, then it runs under docker (not on directly on the OS) so I am not sure how docker communicates to i2c devices.
Also note: that node is over 5y old (so may not work)
there are several other i2c nodes nodes available. Perhaps you could use node-red-contrib-i2c (node) - Node-RED to communicate with the device?
