I am trying to install the ina3221 modules in my node-red, please can you help me with the procedure
I able to found only ina219 modules and found this script in GitHub
https://github.com/easybotics/node-red-contrib-easybotics-ina3221
Please can you help me with
Thank
Your best bet is to contact the author of the node and see if they can help.
For sure, contact the author. I just had a quick read through the code. Even though it looks like a node, it’s not. It appears to be either a script or library that communicates with ina3221. Its missing the required “node-red” keyword for it to show up in the palette, but that’s actually good here as the package.json file doesn’t have the nodes defined it would install. So I looked further and notice it didn’t include an actual node just that script.
There’s an open issue (some 6 months ago) asking for install instructions, to which no response was given so far.
On top of that, the script starts with
var i2c = require('../i2c-bus') // https://github.com/fivdi/i2c-bus
Meaning it references a locally installed library that isn’t included. While a library with that name is listed as dependency, it won’t be located at the path supplied upon installing.
