The node-red-contrib-i2c is saying unsupported in NodRed version 2.2.2
npm -v 8.5.0
The I2C is working on the console, so looks like somthenthing with nodred.
With NodRed 2.2.0 it works great.
Is there somthing I can do to fix ?
npm -v 8.5.0
Show us the exact error message and explain how/where it was shown.
Look in the Node-RED logs (the system console not the browser) it should have printed an error message.
4 Apr 10:14:28 - [info] Starting flows
4 Apr 10:14:28 - [info] [i2c in:I2C IO IN] Couldn't load i2c-bus, is your platform supported ?
Error: The module '/home/pi/.node-red/node_modules/i2c-bus/build/Release/i2c.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 83. This version of Node.js requires
NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
the module (for instance, using npm rebuild or npm install).
at Object.Module._extensions..node (node:internal/modules/cjs/loader:1187:18)
at Module.load (node:internal/modules/cjs/loader:981:32)
at Function.Module._load (node:internal/modules/cjs/loader:822:12)
at Module.require (node:internal/modules/cjs/loader:1005:19)
at require (node:internal/modules/cjs/helpers:102:18)
at bindings (/home/pi/.node-red/node_modules/bindings/bindings.js:112:48)
at Object. (/home/pi/.node-red/node_modules/i2c-bus/i2c-bus.js:4:32)
at Module._compile (node:internal/modules/cjs/loader:1103:14)
at Object.Module._extensions..js (node:internal/modules/cjs/loader:1157:10)
at module.exports (/home/pi/.node-red/node_modules/node-red-contrib-i2c/i2c/26-i2c.js:4:19)
at loadNodeSet (/usr/local/lib/node_modules/node-red/node_modules/@node-red/registry/lib/loader.js:365:27)
at /usr/local/lib/node_modules/node-red/node_modules/@node-red/registry/lib/loader.js:459:31 {
code: 'ERR_DLOPEN_FAILED'
I already did:
pi@nodered:~ $ npm install node-red-contrib-i2c
up to date, audited 6 packages in 3s
found 0 vulnerabilities
and
npm rebuild
I don't know how npm works but maybe its needs fully removing and then re-installing?
You need to run npm rebuild from in the userDir not your home directory (which is what your last post shows).
The default useDir is /home/pi/.node-red
Have you installed n or nvm?
What does running the 2 below commands show you? ...
node --version
sudo node --version
Lastly, have you recently updated node-js?
pi@nodered:~ $
this is the wrong directory.
You should be in /home/pi/.node-red before running npm
[edit]
What @hardillb says
Hi hardillb and all,
thanks a lot, the dir was the issue.
