Help with listing mongoDB collections
I am writing code for a small administrative database. One of the things I need from the database is the ability to list existing collections and list them in checkboxes. However, I am unable to do this. Attached is the code I am using. At this point, I just need an array containing the collections that are already registered. My flow is attached.
I am using node-red-contrib-mongodb4
        "id": "f33ae0340cb92cfd",
        "type": "mongodb4",
        "z": "012812a26a41e597",
        "clientNode": "079563e7e443328f",
        "mode": "db",
        "collection": "",
        "operation": "getCollectionInfos",
        "output": "toArray",
        "maxTimeMS": "0",
        "handleDocId": false,
        "x": 1170,
        "y": 360,
                "f652a658efb090bf"
        "id": "f652a658efb090bf",
        "type": "debug",
        "name": "debug 5",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 1380,
        "y": 360,
        "id": "7105457f780bf9e4",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 800,
        "y": 360,
                "db80ab283244da62"
        "id": "db80ab283244da62",
        "type": "function",
        "name": "Def. ",
        "func": "const query = {\n    listCollections: 1.0,\n    authorizedCollections: true,\n    nameOnly: true\n};\n\nconst options = {}; \n\nmsg.payload = [query, options];\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 990,
        "y": 360,
                "f33ae0340cb92cfd"
        "id": "079563e7e443328f",
        "type": "mongodb4-client",
        "protocol": "mongodb",
        "hostname": "",
        "port": "27017",
        "dbName": "Componentes",
        "appName": "",
        "authSource": "",
        "authMechanism": "DEFAULT",
        "tls": false,
        "tlsCAFile": "",
        "tlsCertificateKeyFile": "",
        "tlsInsecure": false,
        "connectTimeoutMS": "30000",
        "socketTimeoutMS": "0",
        "minPoolSize": "0",
        "maxPoolSize": "100",
        "maxIdleTimeMS": "0",
        "uri": "",
        "advanced": "{}",
        "uriTabActive": "tab-uri-simple"
Hi .. I managed to get a list of Collections by setting the Mode to database operation
but the Operation i left blank and I set it in the Function node as command instead of getCollectionInfos
msg.operation = "command"
msg.payload = {
