Help with switch node expression
I have a property that is a string. I only want to let the message thorugh the switch node if the number after the second dash - is 1.
A string that would pass looks like this:
PP-12345-1
A string that would not pass looks like this:
PP-12345-2-4-1
If I select "contains" and put in -1 the it also matches every message that has 1 after the first dash, which is not what I want.
Can anyone help me with this?
edit I misread your issue.
Let me retry.
$split(msg.payload,"-")[2]
Using a jsonata expression, split the incoming payload, get the 2nd element (starting from 0), if equal to 1, pass message
Anyone else know? :slight_smile:
I gave you a solution ?
Yes you did, sorry. It works perfectly, thanks!
