(This was originally posted on Reddit, but got no response. I have changed my system since then, it's mostly the same)
I have a very simple (for testing) flow to testing TTS - listed below. When I trigger it in Node-Red I get the debug output but nothing is spoken. If I then copy and paste the JSON into MQTT Explorer I get the speech.
- Node-Red version: 1.3.3 (in Linux Docker)
- Rhasspy version: 2.5.10 (on Raspberry Pi 4 Docker) with reSpeaker 2 hat.
- Mosquitto version 2.10 (on Linux Docker)
[{"id":"296dc5d5.fa270a","type":"tab","label":"TESTING","disabled":false,"info":""},{"id":"1e20a9e9.83f226","type":"inject","z":"296dc5d5.fa270a","name":"","props":[{"p":"payload"},{"p":"siteId","v":"Lounge","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"Welcome to the thunder dome","payloadType":"str","x":290,"y":220,"wires":[["c6d77012.a0042"]]},{"id":"c6d77012.a0042","type":"function","z":"296dc5d5.fa270a","name":"To TTS","func":"msg.topic = \"hermes/tts/say\";\nmsg.text = msg.payload;\n\n//msg.topic = \"hermes/dialogueManager/startSession\";\n//msg.init = {};\n//msg.init.type = \"notification\";\n//msg.init.text = msg.payload;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":440,"y":220,"wires":[["45eed33a.ecde3c","49e733e0.e6f3bc"]]},{"id":"45eed33a.ecde3c","type":"mqtt out","z":"296dc5d5.fa270a","name":"TTS Output","topic":"","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"3fa40965.92a3d6","x":610,"y":240,"wires":[]},{"id":"49e733e0.e6f3bc","type":"debug","z":"296dc5d5.fa270a","name":"TTS Output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":610,"y":200,"wires":[]},{"id":"3fa40965.92a3d6","type":"mqtt-broker","name":"MQTT Server","broker":"192.168.1.100","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"10","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
Can anyone help or point me to where to look? Thanks
