New plugin: node-red-contrib-short-circuit
Hi all,
I made a small editor plugin called node-red-contrib-short-circuit.
It hides very long wires in the editor and replaces them with short endpoints, which helps keep larger flows a bit cleaner.
You can:
- Hover an endpoint to see which node it connects to
- Click the preview to jump to that node
- Click the endpoint or node to temporarily show the full connection as a dashed wire
- Change the distance threshold in the plugin configuration file
Nothing in the flow itself is changed or saved differently. It is only a visual editor feature.
Package: node-red-contrib-short-circuit
I made this after I made the node-red-contrib-quick-link which made me think. I might merge these and others into a single one at one point.
Feedback, bugs and ideas are welcome!
That sounds terrific.
Some of those are what the link nodes should have.
Like jumping to the other end.
I'm going to give t a go.
I'm using 4.0.9
The click on the preview to jump to that node doesn't seem to be working.
Does it scroll the screen?
Ok, note to people:
It only kinda works if the other node is NOT visible. Then the screen scrolls/puts the other end in the middle of the screen.
So it doesn't work if one node is at one side and the other is at the opposite side.
Have not tested it on lower versions, but good to hear it works.
The node is indeed not being centered when clicking and only works when its outside your FOV.
I am using the native Node Red Go To function. This function can be seen for example when you expand a flow in your explorer and click on any node.
In that example, it won't center if the node is in your FOV.
I will see if I can adjust that gimmick. For this plugin or in general.
Let me know if you like to see anything else added.
4.0.9 works ok. I just messed up with the distance between and both being visible.
I like it.
Big hugs for it.
Though, now I may actually get/use your other one as it is more related to the existing link node/s.
And I use them a fair bit.
Good to hear,
I use it too for my projects. Let me know if you encounter something.
In the future I might depreciate this one and merge both into 1.
For me, the nominal value is more like 1200. Maybe even 1600
800 seems a bit too short.
But to each their own.
It completely depends on your monitor size too. I made this on a laptop screen, while I work on a desktop with a larger monitor.
On my desktop, it feels less cluttered so I dont mind a larger value.
How is this better than link nodes
I updated it, it should now always center the node for you where ever it may be.
Because it automatically applies itself to long wires between nodes.
Blockquote
Its not a link node nor is it mentioned to be better. But if you ask me why its better I would say:
- Its less effort
- Its not 2x a node
- Its automatic
- It cleans any (existing) flow.
This is not a replacement for a link node. Those were made to... well link. Its a replacement for the wire link between nodes.
I even suggested to use links or the link plugin.
