Hide phantomjs.exe
i have installed pm2 and i have windows 10 system.i noticed that when i creat a pdf file phantomjs.exe command line appears. How can i hide it.
thus presumably that is something to do with you creating pdf... As that is not part of core of Node-RED you would need to work with the author of whatever node/package you are using to create pdf.
@dceejay is right this isn't really node-red related but I'll assume you are passing a phantomjs command to a cmd window in some sort of timer flow? Try passing the /min command as well and it should run the cmd window minimised, but it will always spawn a cmd window when the command is being ran by a logged in user.
