Hello everyone,
I have an array of numbers and I need to create a histogram with them, but I don't know how. Something like what I show in the image, where my numbers go from 0 to 6000, for example. A number should not be a bar on the graph, I need them to be more clustered because the array will be long. Thanks.
There is currently no node I can find that will do that. That said, you could try installing a gnuplot.js and passing the data to it and creating a graph. Not as simple as using an existing ui node, but when one doesn't exist....
