Hosting on Azure Web Apps for containers
I’m trying to setup the node red docker image in Azure Web Apps for containers but I can't get the /data directory mounted to the /home directory for data persistence.
I have tried to use the modified image from https://wp.sjkp.dk/running-node-red-docker-container-on-azure-web-app/ and this works, but I think it should be possible to use the standard and latest node red docker image and add the startup command parameter -v /home/data:/data when setting up the container in Azure.
Have anyone succeeded to setup this?
/Jonas
I solved it by using Docker Compose:
services:
nodered:
container_name: node-RED
image: nodered/node-red:latest
volumes:
- ${WEBAPP_STORAGE_HOME}/node-red:/data
ports:
- "1880:1880"
restart: always
I am very new in the container world. I am stuck. Need help. Following are the steps I followed but getting error. Please suggest:
mkdir appcreate
cd appcreate
git clone GitHub - muntasirjoarder/hubpocapps
cd hubpocapps
az group create --location eastus --resource-group hubpocapps
az appservice plan create --name hubpocappsPlan --resource-group hubpocapps --sku S1 --is-linux
az webapp create --resource-group hubpocapps --plan hubpocappsPlan --name hubpocmerakicloudata --multicontainer-config-type compose --multicontainer-config-file hubpocmerakidata.yml
az webapp config appsettings set --resource-group hubpocapps --name hubpocmerakicloudata --settings WEBSITES_ENABLE_APP_SERVICE_STORAGE=true
Hello!
Try to use this Azure ARM-template, it will setup NodeRed in a App Service with all required settings.
You need to edit the deploy.ps1 file with correct location and path.
/Jonas
Thank you. I will try and let you know.
Hi Jonas
Thank you very much. It did work.
I already have a docker node-red instance (hubpoc/node-red-merakidata:latest) with some additional npm packages installed, that I was trying to create web app from. When I modified to the following in nodered.json and created the web app I am getting Application error. Don't know what mistake I did:
"linuxFxVersion": "DOCKER|hubpoc/node-red-merakidata:latest"
Any suggestion will be helpful. I am stuck!!!
What does the log say under "Container Settings" on you App Service?
/Jonas
2021_05_02_lw0sdlwk0000GL_default_docker.log:
2021-05-02T20:21:19.310758119Z internal/modules/cjs/loader.js:883
2021-05-02T20:21:19.310809820Z throw err;
2021-05-02T20:21:19.310816920Z ^
2021-05-02T20:21:19.310851220Z
2021-05-02T20:21:19.310856020Z Error: Cannot find module '/data/server.js'
2021-05-02T20:21:19.310860520Z at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
2021-05-02T20:21:19.310866020Z at Function.Module._load (internal/modules/cjs/loader.js:725:27)
2021-05-02T20:21:19.310870620Z at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
2021-05-02T20:21:19.310874920Z at internal/main/run_main_module.js:17:47 {
2021-05-02T20:21:19.310879220Z code: 'MODULE_NOT_FOUND',
2021-05-02T20:21:19.310883421Z requireStack:
2021-05-02T20:21:19.310887421Z }
2021-05-02T20:21:33.123613344Z internal/modules/cjs/loader.js:883
2021-05-02T20:21:33.123662544Z throw err;
2021-05-02T20:21:33.123668944Z ^
2021-05-02T20:21:33.123672844Z
2021-05-02T20:21:33.123676844Z Error: Cannot find module '/data/server.js'
2021-05-02T20:21:33.123680745Z at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
2021-05-02T20:21:33.123685945Z at Function.Module._load (internal/modules/cjs/loader.js:725:27)
2021-05-02T20:21:33.123689945Z at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
2021-05-02T20:21:33.123693845Z at internal/main/run_main_module.js:17:47 {
2021-05-02T20:21:33.123697645Z code: 'MODULE_NOT_FOUND',
2021-05-02T20:21:33.123701545Z requireStack:
2021-05-02T20:21:33.123705745Z }
2021-05-02T20:26:35.817351598Z internal/modules/cjs/loader.js:883
2021-05-02T20:26:35.817390598Z throw err;
2021-05-02T20:26:35.817397399Z ^
2021-05-02T20:26:35.817401999Z
2021-05-02T20:26:35.817406299Z Error: Cannot find module '/data/server.js'
2021-05-02T20:26:35.817410699Z at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
2021-05-02T20:26:35.817415499Z at Function.Module._load (internal/modules/cjs/loader.js:725:27)
2021-05-02T20:26:35.817419799Z at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
2021-05-02T20:26:35.817423799Z at internal/main/run_main_module.js:17:47 {
2021-05-02T20:26:35.817427999Z code: 'MODULE_NOT_FOUND',
2021-05-02T20:26:35.817432099Z requireStack:
2021-05-02T20:26:35.817436299Z }
2021-05-02T20:31:36.560993063Z internal/modules/cjs/loader.js:883
2021-05-02T20:31:36.561026864Z throw err;
2021-05-02T20:31:36.561032664Z ^
2021-05-02T20:31:36.561036564Z
2021-05-02T20:31:36.561040364Z Error: Cannot find module '/data/server.js'
2021-05-02T20:31:36.561044264Z at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
2021-05-02T20:31:36.561048764Z at Function.Module._load (internal/modules/cjs/loader.js:725:27)
2021-05-02T20:31:36.561052664Z at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
2021-05-02T20:31:36.561063264Z at internal/main/run_main_module.js:17:47 {
2021-05-02T20:31:36.561067164Z code: 'MODULE_NOT_FOUND',
2021-05-02T20:31:36.561070864Z requireStack:
2021-05-02T20:31:36.561074664Z }
2021-05-02T20:32:14.502020173Z internal/modules/cjs/loader.js:883
2021-05-02T20:32:14.502059174Z throw err;
2021-05-02T20:32:14.502064374Z ^
2021-05-02T20:32:14.502067974Z
2021-05-02T20:32:14.502071474Z Error: Cannot find module '/data/server.js'
2021-05-02T20:32:14.502080474Z at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
2021-05-02T20:32:14.502085374Z at Function.Module._load (internal/modules/cjs/loader.js:725:27)
2021-05-02T20:32:14.502089374Z at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
2021-05-02T20:32:14.502093074Z at internal/main/run_main_module.js:17:47 {
2021-05-02T20:32:14.502096574Z code: 'MODULE_NOT_FOUND',
2021-05-02T20:32:14.502099974Z requireStack:
2021-05-02T20:32:14.502103374Z }
2021_05_02_lw0sdlwk0000GL_docker.log:
2021-05-02T20:19:17.704Z INFO - Pulling image from Docker hub: hubpoc/node-red-merakidata:latest
2021-05-02T20:19:18.425Z INFO - latest Pulling from hubpoc/node-red-merakidata
2021-05-02T20:19:18.465Z INFO - 62deabe7a6db Pulling fs layer
2021-05-02T20:19:18.465Z INFO - f698164f6049 Pulling fs layer
2021-05-02T20:19:18.465Z INFO - 2035fb234df3 Pulling fs layer
2021-05-02T20:19:18.465Z INFO - d36882704ea7 Pulling fs layer
2021-05-02T20:19:18.465Z INFO - bc3451790352 Pulling fs layer
2021-05-02T20:19:18.465Z INFO - d00af235b343 Pulling fs layer
2021-05-02T20:19:18.465Z INFO - 2e6d8a415553 Pulling fs layer
2021-05-02T20:19:18.465Z INFO - 03a5e61410af Pulling fs layer
2021-05-02T20:19:18.466Z INFO - ecc0697ef013 Pulling fs layer
2021-05-02T20:19:18.466Z INFO - 092b907bf696 Pulling fs layer
2021-05-02T20:19:18.466Z INFO - 4fcb5ba5b687 Pulling fs layer
2021-05-02T20:19:18.466Z INFO - 1b945a4c843d Pulling fs layer
2021-05-02T20:19:18.474Z INFO - 4016fdf20776 Pulling fs layer
2021-05-02T20:19:18.474Z INFO - 1998d406d152 Pulling fs layer
2021-05-02T20:19:18.474Z INFO - 88d1b0bb51b1 Pulling fs layer
2021-05-02T20:19:19.231Z INFO - bc3451790352 Downloading 293B / 293B
2021-05-02T20:19:19.231Z INFO - bc3451790352 Verifying Checksum
2021-05-02T20:19:19.232Z INFO - bc3451790352 Download complete
2021-05-02T20:19:19.243Z INFO - 2e6d8a415553 Downloading 425B / 4KB
2021-05-02T20:19:19.243Z INFO - 2e6d8a415553 Downloading 4KB / 4KB
2021-05-02T20:19:19.248Z INFO - 2e6d8a415553 Verifying Checksum
2021-05-02T20:19:19.251Z INFO - 2e6d8a415553 Download complete
2021-05-02T20:19:19.302Z INFO - f698164f6049 Downloading 423B / 4KB
2021-05-02T20:19:19.309Z INFO - 1b945a4c843d Downloading 167B / 167B
2021-05-02T20:19:19.309Z INFO - 03a5e61410af Downloading 106B / 106B
2021-05-02T20:19:19.309Z INFO - ecc0697ef013 Downloading 1KB / 1KB
2021-05-02T20:19:19.309Z INFO - f698164f6049 Downloading 4KB / 4KB
2021-05-02T20:19:19.309Z INFO - 1b945a4c843d Verifying Checksum
2021-05-02T20:19:19.309Z INFO - 1b945a4c843d Download complete
2021-05-02T20:19:19.309Z INFO - 03a5e61410af Verifying Checksum
2021-05-02T20:19:19.309Z INFO - 03a5e61410af Download complete
2021-05-02T20:19:19.309Z INFO - ecc0697ef013 Verifying Checksum
2021-05-02T20:19:19.309Z INFO - ecc0697ef013 Download complete
2021-05-02T20:19:19.309Z INFO - f698164f6049 Verifying Checksum
2021-05-02T20:19:19.310Z INFO - f698164f6049 Download complete
2021-05-02T20:19:19.310Z INFO - 092b907bf696 Downloading 425B / 4KB
2021-05-02T20:19:19.320Z INFO - 092b907bf696 Downloading 4KB / 4KB
2021-05-02T20:19:19.320Z INFO - d36882704ea7 Verifying Checksum
2021-05-02T20:19:19.320Z INFO - d36882704ea7 Download complete
2021-05-02T20:19:19.320Z INFO - 092b907bf696 Verifying Checksum
2021-05-02T20:19:19.320Z INFO - 092b907bf696 Download complete
2021-05-02T20:19:19.361Z INFO - 4fcb5ba5b687 Downloading 437B / 1KB
2021-05-02T20:19:19.372Z INFO - 4fcb5ba5b687 Downloading 1KB / 1KB
2021-05-02T20:19:19.379Z INFO - 4fcb5ba5b687 Verifying Checksum
2021-05-02T20:19:19.379Z INFO - 4fcb5ba5b687 Download complete
2021-05-02T20:19:19.412Z INFO - d00af235b343 Downloading 862KB / 9MB
2021-05-02T20:19:19.462Z INFO - 2035fb234df3 Downloading 2MB / 33MB
2021-05-02T20:19:19.462Z INFO - 4016fdf20776 Downloading 512B / 512B
2021-05-02T20:19:19.462Z INFO - 4016fdf20776 Verifying Checksum
2021-05-02T20:19:19.463Z INFO - 4016fdf20776 Download complete
2021-05-02T20:19:19.561Z INFO - 1998d406d152 Downloading 1MB / 17MB
2021-05-02T20:19:19.590Z INFO - 2035fb234df3 Downloading 4MB / 33MB
2021-05-02T20:19:19.613Z INFO - 62deabe7a6db Downloading 1MB / 21MB
2021-05-02T20:19:19.681Z INFO - 88d1b0bb51b1 Downloading 1MB / 17MB
2021-05-02T20:19:19.924Z INFO - 88d1b0bb51b1 Downloading 1MB / 17MB
2021-05-02T20:19:19.984Z INFO - 1998d406d152 Downloading 3MB / 17MB
2021-05-02T20:19:20.004Z INFO - 88d1b0bb51b1 Downloading 3MB / 17MB
2021-05-02T20:19:20.084Z INFO - 1998d406d152 Downloading 5MB / 17MB
2021-05-02T20:19:20.106Z INFO - 62deabe7a6db Downloading 4MB / 21MB
2021-05-02T20:19:20.163Z INFO - 2035fb234df3 Downloading 7MB / 33MB
2021-05-02T20:19:20.175Z INFO - 88d1b0bb51b1 Downloading 4MB / 17MB
2021-05-02T20:19:20.254Z INFO - 62deabe7a6db Downloading 5MB / 21MB
2021-05-02T20:19:20.326Z INFO - 88d1b0bb51b1 Downloading 6MB / 17MB
2021-05-02T20:19:20.326Z INFO - d00af235b343 Downloading 7MB / 9MB
2021-05-02T20:19:20.418Z INFO - d00af235b343 Verifying Checksum
2021-05-02T20:19:20.418Z INFO - d00af235b343 Download complete
2021-05-02T20:19:20.599Z INFO - 1998d406d152 Downloading 11MB / 17MB
2021-05-02T20:19:20.599Z INFO - 62deabe7a6db Downloading 10MB / 21MB
2021-05-02T20:19:20.629Z INFO - 2035fb234df3 Downloading 12MB / 33MB
2021-05-02T20:19:20.657Z INFO - 62deabe7a6db Downloading 11MB / 21MB
2021-05-02T20:19:20.706Z INFO - 1998d406d152 Downloading 12MB / 17MB
2021-05-02T20:19:20.729Z INFO - 2035fb234df3 Downloading 14MB / 33MB
2021-05-02T20:19:20.830Z INFO - 88d1b0bb51b1 Downloading 12MB / 17MB
2021-05-02T20:19:20.830Z INFO - 62deabe7a6db Downloading 13MB / 21MB
2021-05-02T20:19:20.910Z INFO - 2035fb234df3 Downloading 16MB / 33MB
2021-05-02T20:19:21.019Z INFO - 88d1b0bb51b1 Downloading 15MB / 17MB
2021-05-02T20:19:21.019Z INFO - 1998d406d152 Downloading 16MB / 17MB
2021-05-02T20:19:21.069Z INFO - 62deabe7a6db Downloading 18MB / 21MB
2021-05-02T20:19:21.069Z INFO - 1998d406d152 Verifying Checksum
2021-05-02T20:19:21.070Z INFO - 1998d406d152 Download complete
2021-05-02T20:19:21.119Z INFO - 2035fb234df3 Downloading 20MB / 33MB
2021-05-02T20:19:21.119Z INFO - 88d1b0bb51b1 Downloading 17MB / 17MB
2021-05-02T20:19:21.119Z INFO - 88d1b0bb51b1 Verifying Checksum
2021-05-02T20:19:21.120Z INFO - 88d1b0bb51b1 Download complete
2021-05-02T20:19:21.161Z INFO - 62deabe7a6db Verifying Checksum
2021-05-02T20:19:21.161Z INFO - 62deabe7a6db Download complete
2021-05-02T20:19:21.523Z INFO - 62deabe7a6db Extracting 448KB / 21MB
2021-05-02T20:19:21.551Z INFO - 2035fb234df3 Verifying Checksum
2021-05-02T20:19:21.552Z INFO - 2035fb234df3 Download complete
2021-05-02T20:19:21.661Z INFO - 62deabe7a6db Extracting 896KB / 21MB
2021-05-02T20:19:22.399Z INFO - 62deabe7a6db Extracting 3MB / 21MB
2021-05-02T20:19:23.203Z INFO - 62deabe7a6db Extracting 10MB / 21MB
2021-05-02T20:19:23.452Z INFO - 62deabe7a6db Extracting 12MB / 21MB
2021-05-02T20:19:23.805Z INFO - 62deabe7a6db Extracting 14MB / 21MB
2021-05-02T20:19:23.966Z INFO - 62deabe7a6db Extracting 15MB / 21MB
2021-05-02T20:19:24.077Z INFO - 62deabe7a6db Extracting 16MB / 21MB
2021-05-02T20:19:25.018Z INFO - 62deabe7a6db Extracting 19MB / 21MB
2021-05-02T20:19:25.452Z INFO - 62deabe7a6db Extracting 20MB / 21MB
2021-05-02T20:19:26.358Z INFO - 62deabe7a6db Extracting 20MB / 21MB
2021-05-02T20:19:26.508Z INFO - 62deabe7a6db Extracting 21MB / 21MB
2021-05-02T20:19:26.759Z INFO - 62deabe7a6db Extracting 21MB / 21MB
2021-05-02T20:19:42.147Z INFO - 62deabe7a6db Pull complete
2021-05-02T20:19:42.232Z INFO - f698164f6049 Extracting 4KB / 4KB
2021-05-02T20:19:42.235Z INFO - f698164f6049 Extracting 4KB / 4KB
2021-05-02T20:19:42.574Z INFO - f698164f6049 Pull complete
2021-05-02T20:19:42.948Z INFO - 2035fb234df3 Extracting 1MB / 33MB
2021-05-02T20:19:43.050Z INFO - 2035fb234df3 Extracting 2MB / 33MB
2021-05-02T20:19:43.152Z INFO - 2035fb234df3 Extracting 2MB / 33MB
2021-05-02T20:19:43.272Z INFO - 2035fb234df3 Extracting 3MB / 33MB
2021-05-02T20:19:43.403Z INFO - 2035fb234df3 Extracting 4MB / 33MB
2021-05-02T20:19:43.562Z INFO - 2035fb234df3 Extracting 4MB / 33MB
2021-05-02T20:19:43.804Z INFO - 2035fb234df3 Extracting 6MB / 33MB
2021-05-02T20:19:43.955Z INFO - 2035fb234df3 Extracting 8MB / 33MB
2021-05-02T20:19:44.178Z INFO - 2035fb234df3 Extracting 10MB / 33MB
2021-05-02T20:19:44.357Z INFO - 2035fb234df3 Extracting 11MB / 33MB
2021-05-02T20:19:44.510Z INFO - 2035fb234df3 Extracting 11MB / 33MB
2021-05-02T20:19:44.670Z INFO - 2035fb234df3 Extracting 12MB / 33MB
2021-05-02T20:19:45.032Z INFO - 2035fb234df3 Extracting 16MB / 33MB
2021-05-02T20:19:45.273Z INFO - 2035fb234df3 Extracting 18MB / 33MB
2021-05-02T20:19:45.505Z INFO - 2035fb234df3 Extracting 20MB / 33MB
2021-05-02T20:19:45.866Z INFO - 2035fb234df3 Extracting 23MB / 33MB
2021-05-02T20:19:46.217Z INFO - 2035fb234df3 Extracting 26MB / 33MB
2021-05-02T20:19:46.630Z INFO - 2035fb234df3 Extracting 27MB / 33MB
2021-05-02T20:19:47.444Z INFO - 2035fb234df3 Extracting 29MB / 33MB
2021-05-02T20:19:47.858Z INFO - 2035fb234df3 Extracting 30MB / 33MB
2021-05-02T20:19:48.187Z INFO - 2035fb234df3 Extracting 30MB / 33MB
2021-05-02T20:19:48.923Z INFO - 2035fb234df3 Extracting 32MB / 33MB
2021-05-02T20:19:49.295Z INFO - 2035fb234df3 Extracting 33MB / 33MB
2021-05-02T20:19:49.548Z INFO - 2035fb234df3 Extracting 33MB / 33MB
2021-05-02T20:19:54.790Z INFO - 2035fb234df3 Pull complete
2021-05-02T20:19:55.592Z INFO - d36882704ea7 Extracting 192KB / 2MB
2021-05-02T20:19:55.711Z INFO - d36882704ea7 Extracting 352KB / 2MB
2021-05-02T20:19:55.924Z INFO - d36882704ea7 Extracting 672KB / 2MB
2021-05-02T20:19:56.115Z INFO - d36882704ea7 Extracting 960KB / 2MB
2021-05-02T20:19:56.164Z INFO - d36882704ea7 Extracting 1MB / 2MB
2021-05-02T20:19:56.850Z INFO - d36882704ea7 Extracting 2MB / 2MB
2021-05-02T20:20:05.889Z INFO - d36882704ea7 Pull complete
2021-05-02T20:20:05.937Z INFO - bc3451790352 Extracting 293B / 293B
2021-05-02T20:20:05.938Z INFO - bc3451790352 Extracting 293B / 293B
2021-05-02T20:20:06.203Z INFO - bc3451790352 Pull complete
2021-05-02T20:20:06.448Z INFO - d00af235b343 Extracting 256KB / 9MB
2021-05-02T20:20:06.799Z INFO - d00af235b343 Extracting 2MB / 9MB
2021-05-02T20:20:06.901Z INFO - d00af235b343 Extracting 2MB / 9MB
2021-05-02T20:20:07.029Z INFO - d00af235b343 Extracting 3MB / 9MB
2021-05-02T20:20:07.139Z INFO - d00af235b343 Extracting 3MB / 9MB
2021-05-02T20:20:07.461Z INFO - d00af235b343 Extracting 5MB / 9MB
2021-05-02T20:20:07.564Z INFO - d00af235b343 Extracting 6MB / 9MB
2021-05-02T20:20:07.975Z INFO - d00af235b343 Extracting 7MB / 9MB
2021-05-02T20:20:08.116Z INFO - d00af235b343 Extracting 7MB / 9MB
2021-05-02T20:20:08.256Z INFO - d00af235b343 Extracting 8MB / 9MB
2021-05-02T20:20:08.499Z INFO - d00af235b343 Extracting 8MB / 9MB
2021-05-02T20:20:09.081Z INFO - d00af235b343 Extracting 9MB / 9MB
2021-05-02T20:20:14.656Z INFO - d00af235b343 Pull complete
2021-05-02T20:20:14.980Z INFO - 2e6d8a415553 Extracting 4KB / 4KB
2021-05-02T20:20:15.469Z INFO - 2e6d8a415553 Pull complete
2021-05-02T20:20:15.547Z INFO - 03a5e61410af Extracting 106B / 106B
2021-05-02T20:20:15.548Z INFO - 03a5e61410af Extracting 106B / 106B
2021-05-02T20:20:16.283Z INFO - 03a5e61410af Pull complete
2021-05-02T20:20:16.331Z INFO - ecc0697ef013 Extracting 1KB / 1KB
2021-05-02T20:20:16.332Z INFO - ecc0697ef013 Extracting 1KB / 1KB
2021-05-02T20:20:16.933Z INFO - ecc0697ef013 Pull complete
2021-05-02T20:20:16.974Z INFO - 092b907bf696 Extracting 4KB / 4KB
2021-05-02T20:20:16.975Z INFO - 092b907bf696 Extracting 4KB / 4KB
2021-05-02T20:20:17.291Z INFO - 092b907bf696 Pull complete
2021-05-02T20:20:17.326Z INFO - 4fcb5ba5b687 Extracting 1KB / 1KB
2021-05-02T20:20:17.327Z INFO - 4fcb5ba5b687 Extracting 1KB / 1KB
2021-05-02T20:20:17.558Z INFO - 4fcb5ba5b687 Pull complete
2021-05-02T20:20:17.598Z INFO - 1b945a4c843d Extracting 167B / 167B
2021-05-02T20:20:17.599Z INFO - 1b945a4c843d Extracting 167B / 167B
2021-05-02T20:20:17.853Z INFO - 1b945a4c843d Pull complete
2021-05-02T20:20:17.884Z INFO - 4016fdf20776 Extracting 512B / 512B
2021-05-02T20:20:17.885Z INFO - 4016fdf20776 Extracting 512B / 512B
2021-05-02T20:20:18.116Z INFO - 4016fdf20776 Pull complete
2021-05-02T20:20:18.542Z INFO - 1998d406d152 Extracting 768KB / 17MB
2021-05-02T20:20:18.793Z INFO - 1998d406d152 Extracting 1MB / 17MB
2021-05-02T20:20:19.458Z INFO - 1998d406d152 Extracting 1MB / 17MB
2021-05-02T20:20:19.729Z INFO - 1998d406d152 Extracting 2MB / 17MB
2021-05-02T20:20:19.831Z INFO - 1998d406d152 Extracting 3MB / 17MB
2021-05-02T20:20:20.162Z INFO - 1998d406d152 Extracting 4MB / 17MB
2021-05-02T20:20:20.263Z INFO - 1998d406d152 Extracting 5MB / 17MB
2021-05-02T20:20:20.483Z INFO - 1998d406d152 Extracting 5MB / 17MB
2021-05-02T20:20:21.216Z INFO - 1998d406d152 Extracting 6MB / 17MB
2021-05-02T20:20:22.663Z INFO - 1998d406d152 Extracting 8MB / 17MB
2021-05-02T20:20:23.000Z INFO - 1998d406d152 Extracting 9MB / 17MB
2021-05-02T20:20:23.410Z INFO - 1998d406d152 Extracting 9MB / 17MB
2021-05-02T20:20:23.662Z INFO - 1998d406d152 Extracting 10MB / 17MB
2021-05-02T20:20:23.782Z INFO - 1998d406d152 Extracting 10MB / 17MB
2021-05-02T20:20:23.991Z INFO - 1998d406d152 Extracting 11MB / 17MB
2021-05-02T20:20:24.131Z INFO - 1998d406d152 Extracting 12MB / 17MB
2021-05-02T20:20:25.087Z INFO - 1998d406d152 Extracting 13MB / 17MB
2021-05-02T20:20:25.791Z INFO - 1998d406d152 Extracting 14MB / 17MB
2021-05-02T20:20:26.547Z INFO - 1998d406d152 Extracting 15MB / 17MB
2021-05-02T20:20:26.940Z INFO - 1998d406d152 Extracting 16MB / 17MB
2021-05-02T20:20:27.503Z INFO - 1998d406d152 Extracting 17MB / 17MB
2021-05-02T20:20:27.752Z INFO - 1998d406d152 Extracting 17MB / 17MB
2021-05-02T20:20:41.227Z INFO - 1998d406d152 Pull complete
2021-05-02T20:20:41.674Z INFO - 88d1b0bb51b1 Extracting 768KB / 17MB
2021-05-02T20:20:41.965Z INFO - 88d1b0bb51b1 Extracting 1MB / 17MB
2021-05-02T20:20:42.308Z INFO - 88d1b0bb51b1 Extracting 1MB / 17MB
2021-05-02T20:20:42.537Z INFO - 88d1b0bb51b1 Extracting 1MB / 17MB
2021-05-02T20:20:42.980Z INFO - 88d1b0bb51b1 Extracting 2MB / 17MB
2021-05-02T20:20:43.090Z INFO - 88d1b0bb51b1 Extracting 3MB / 17MB
2021-05-02T20:20:43.495Z INFO - 88d1b0bb51b1 Extracting 4MB / 17MB
2021-05-02T20:20:43.796Z INFO - 88d1b0bb51b1 Extracting 5MB / 17MB
2021-05-02T20:20:44.179Z INFO - 88d1b0bb51b1 Extracting 6MB / 17MB
2021-05-02T20:20:44.308Z INFO - 88d1b0bb51b1 Extracting 6MB / 17MB
2021-05-02T20:20:44.409Z INFO - 88d1b0bb51b1 Extracting 6MB / 17MB
2021-05-02T20:20:45.375Z INFO - 88d1b0bb51b1 Extracting 8MB / 17MB
2021-05-02T20:20:45.897Z INFO - 88d1b0bb51b1 Extracting 9MB / 17MB
2021-05-02T20:20:45.998Z INFO - 88d1b0bb51b1 Extracting 9MB / 17MB
2021-05-02T20:20:46.448Z INFO - 88d1b0bb51b1 Extracting 10MB / 17MB
2021-05-02T20:20:46.679Z INFO - 88d1b0bb51b1 Extracting 10MB / 17MB
2021-05-02T20:20:46.901Z INFO - 88d1b0bb51b1 Extracting 12MB / 17MB
2021-05-02T20:20:47.032Z INFO - 88d1b0bb51b1 Extracting 12MB / 17MB
2021-05-02T20:20:47.614Z INFO - 88d1b0bb51b1 Extracting 13MB / 17MB
2021-05-02T20:20:48.329Z INFO - 88d1b0bb51b1 Extracting 14MB / 17MB
2021-05-02T20:20:48.709Z INFO - 88d1b0bb51b1 Extracting 14MB / 17MB
2021-05-02T20:20:49.422Z INFO - 88d1b0bb51b1 Extracting 15MB / 17MB
2021-05-02T20:20:49.595Z INFO - 88d1b0bb51b1 Extracting 15MB / 17MB
2021-05-02T20:20:49.847Z INFO - 88d1b0bb51b1 Extracting 15MB / 17MB
2021-05-02T20:20:50.981Z INFO - 88d1b0bb51b1 Extracting 16MB / 17MB
2021-05-02T20:20:51.539Z INFO - 88d1b0bb51b1 Extracting 17MB / 17MB
2021-05-02T20:20:51.763Z INFO - 88d1b0bb51b1 Extracting 17MB / 17MB
2021-05-02T20:21:03.266Z INFO - 88d1b0bb51b1 Pull complete
2021-05-02T20:21:03.309Z INFO - Digest: sha256:069f4e0c13bd42658181df83e49527f934c0fa54aec12f09487b74821a4e32ed
2021-05-02T20:21:03.340Z INFO - Status: Downloaded newer image for hubpoc/node-red-merakidata:latest
2021-05-02T20:21:03.345Z INFO - Pull Image successful, Time taken: 1 Minutes and 45 Seconds
2021-05-02T20:21:03.376Z INFO - Starting container for site
2021-05-02T20:21:03.376Z INFO - docker run -d -p 8722:1880 --name testhubapp_0_1bf88061 -e WEBSITE_SITE_NAME=testhubapp -e WEBSITE_AUTH_ENABLED=False -e PORT=1880 -e WEBSITE_ROLE_INSTANCE_ID=0 -e WEBSITE_HOSTNAME=testhubapp.azurewebsites.net -e WEBSITE_INSTANCE_ID=9dead3715cfabf4121227c7b50ed47ff10d83fa4ce409893ec6050f6aee91951 hubpoc/node-red-merakidata:latest
2021-05-02T20:21:03.376Z INFO - Logging is not enabled for this container.
Please use https://aka.ms/linux-diagnostics to enable logging to see container logs here.
2021-05-02T20:21:08.121Z INFO - Initiating warmup request to container testhubapp_0_1bf88061 for site testhubapp
2021-05-02T20:21:11.249Z INFO - Container testhubapp_0_1bf88061 for site testhubapp initialized successfully and is ready to serve requests.
2021-05-02T20:21:12.865Z INFO - Recycling container because of AzureStorageAccountsChange and isMainSite = True
2021-05-02T20:21:13.931Z INFO - Pulling image from Docker hub: hubpoc/node-red-merakidata:latest
2021-05-02T20:21:14.906Z INFO - latest Pulling from hubpoc/node-red-merakidata
2021-05-02T20:21:14.976Z INFO - Digest: sha256:069f4e0c13bd42658181df83e49527f934c0fa54aec12f09487b74821a4e32ed
2021-05-02T20:21:14.984Z INFO - Status: Image is up to date for hubpoc/node-red-merakidata:latest
2021-05-02T20:21:15.056Z INFO - Pull Image successful, Time taken: 0 Minutes and 1 Seconds
2021-05-02T20:21:15.298Z INFO - Starting container for site
2021-05-02T20:21:15.305Z INFO - docker run -d -p 2897:1880 --name testhubapp_1_ccda12ba -e WEBSITE_SITE_NAME=testhubapp -e WEBSITE_AUTH_ENABLED=False -e PORT=1880 -e WEBSITE_ROLE_INSTANCE_ID=0 -e WEBSITE_HOSTNAME=testhubapp.azurewebsites.net -e WEBSITE_INSTANCE_ID=9dead3715cfabf4121227c7b50ed47ff10d83fa4ce409893ec6050f6aee91951 hubpoc/node-red-merakidata:latest
2021-05-02T20:21:15.307Z INFO - Logging is not enabled for this container.
2021-05-02T20:21:19.280Z INFO - Initiating warmup request to container testhubapp_1_ccda12ba for site testhubapp
2021-05-02T20:21:20.626Z ERROR - Container testhubapp_1_ccda12ba for site testhubapp has exited, failing site start
2021-05-02T20:21:20.630Z ERROR - Container testhubapp_1_ccda12ba didn't respond to HTTP pings on port: 1880, failing site start. See container logs for debugging.
2021-05-02T20:21:30.094Z INFO - Pulling image from Docker hub: hubpoc/node-red-merakidata:latest
2021-05-02T20:21:30.246Z INFO - latest Pulling from hubpoc/node-red-merakidata
2021-05-02T20:21:30.248Z INFO - Digest: sha256:069f4e0c13bd42658181df83e49527f934c0fa54aec12f09487b74821a4e32ed
2021-05-02T20:21:30.249Z INFO - Status: Image is up to date for hubpoc/node-red-merakidata:latest
2021-05-02T20:21:30.252Z INFO - Pull Image successful, Time taken: 0 Minutes and 0 Seconds
2021-05-02T20:21:30.271Z INFO - Starting container for site
2021-05-02T20:21:30.272Z INFO - docker run -d -p 7758:1880 --name testhubapp_0_5f30f666 -e WEBSITE_SITE_NAME=testhubapp -e WEBSITE_AUTH_ENABLED=False -e PORT=1880 -e WEBSITE_ROLE_INSTANCE_ID=0 -e WEBSITE_HOSTNAME=testhubapp.azurewebsites.net -e WEBSITE_INSTANCE_ID=9dead3715cfabf4121227c7b50ed47ff10d83fa4ce409893ec6050f6aee91951 hubpoc/node-red-merakidata:latest
2021-05-02T20:21:30.273Z INFO - Logging is not enabled for this container.
2021-05-02T20:21:32.975Z INFO - Initiating warmup request to container testhubapp_0_5f30f666 for site testhubapp
2021-05-02T20:21:34.084Z ERROR - Container testhubapp_0_5f30f666 for site testhubapp has exited, failing site start
2021-05-02T20:21:34.086Z ERROR - Container testhubapp_0_5f30f666 didn't respond to HTTP pings on port: 1880, failing site start. See container logs for debugging.
2021-05-02T20:21:34.095Z INFO - Stopping site testhubapp because it failed during startup.
2021-05-02T20:26:29.491Z INFO - Pulling image from Docker hub: hubpoc/node-red-merakidata:latest
2021-05-02T20:26:29.630Z INFO - latest Pulling from hubpoc/node-red-merakidata
2021-05-02T20:26:29.631Z INFO - Digest: sha256:069f4e0c13bd42658181df83e49527f934c0fa54aec12f09487b74821a4e32ed
2021-05-02T20:26:29.632Z INFO - Status: Image is up to date for hubpoc/node-red-merakidata:latest
2021-05-02T20:26:29.637Z INFO - Pull Image successful, Time taken: 0 Minutes and 0 Seconds
2021-05-02T20:26:29.664Z INFO - Starting container for site
2021-05-02T20:26:29.666Z INFO - docker run -d -p 5127:1880 --name testhubapp_0_f173d1cb -e WEBSITE_SITE_NAME=testhubapp -e WEBSITE_AUTH_ENABLED=False -e PORT=1880 -e WEBSITE_ROLE_INSTANCE_ID=0 -e WEBSITE_HOSTNAME=testhubapp.azurewebsites.net -e WEBSITE_INSTANCE_ID=9dead3715cfabf4121227c7b50ed47ff10d83fa4ce409893ec6050f6aee91951 hubpoc/node-red-merakidata:latest
2021-05-02T20:26:29.672Z INFO - Logging is not enabled for this container.
2021-05-02T20:26:35.038Z INFO - Initiating warmup request to container testhubapp_0_f173d1cb for site testhubapp
2021-05-02T20:26:37.571Z ERROR - Container testhubapp_0_f173d1cb for site testhubapp has exited, failing site start
2021-05-02T20:26:37.573Z ERROR - Container testhubapp_0_f173d1cb didn't respond to HTTP pings on port: 1880, failing site start. See container logs for debugging.
2021-05-02T20:26:37.576Z INFO - Stopping site testhubapp because it failed during startup.
2021-05-02T20:31:30.593Z INFO - Pulling image from Docker hub: hubpoc/node-red-merakidata:latest
2021-05-02T20:31:30.735Z INFO - latest Pulling from hubpoc/node-red-merakidata
2021-05-02T20:31:30.737Z INFO - Digest: sha256:069f4e0c13bd42658181df83e49527f934c0fa54aec12f09487b74821a4e32ed
2021-05-02T20:31:30.738Z INFO - Status: Image is up to date for hubpoc/node-red-merakidata:latest
2021-05-02T20:31:30.741Z INFO - Pull Image successful, Time taken: 0 Minutes and 0 Seconds
2021-05-02T20:31:30.759Z INFO - Starting container for site
2021-05-02T20:31:30.766Z INFO - docker run -d -p 7152:1880 --name testhubapp_0_7e7bfbe5 -e WEBSITE_SITE_NAME=testhubapp -e WEBSITE_AUTH_ENABLED=False -e PORT=1880 -e WEBSITE_ROLE_INSTANCE_ID=0 -e WEBSITE_HOSTNAME=testhubapp.azurewebsites.net -e WEBSITE_INSTANCE_ID=9dead3715cfabf4121227c7b50ed47ff10d83fa4ce409893ec6050f6aee91951 hubpoc/node-red-merakidata:latest
2021-05-02T20:31:30.768Z INFO - Logging is not enabled for this container.
2021-05-02T20:31:35.776Z INFO - Initiating warmup request to container testhubapp_0_7e7bfbe5 for site testhubapp
2021-05-02T20:31:37.859Z ERROR - Container testhubapp_0_7e7bfbe5 for site testhubapp has exited, failing site start
2021-05-02T20:31:37.861Z ERROR - Container testhubapp_0_7e7bfbe5 didn't respond to HTTP pings on port: 1880, failing site start. See container logs for debugging.
2021-05-02T20:31:37.881Z INFO - Stopping site testhubapp because it failed during startup.
2021-05-02T20:32:05.187Z INFO - Pulling image from Docker hub: hubpoc/node-red-merakidata:latest
2021-05-02T20:32:05.981Z INFO - latest Pulling from hubpoc/node-red-merakidata
2021-05-02T20:32:05.983Z INFO - Digest: sha256:069f4e0c13bd42658181df83e49527f934c0fa54aec12f09487b74821a4e32ed
2021-05-02T20:32:05.984Z INFO - Status: Image is up to date for hubpoc/node-red-merakidata:latest
2021-05-02T20:32:05.987Z INFO - Pull Image successful, Time taken: 0 Minutes and 0 Seconds
2021-05-02T20:32:06.033Z INFO - Starting container for site
2021-05-02T20:32:06.040Z INFO - docker run -d -p 3656:1880 --name testhubapp_0_61835bb6 -e WEBSITE_SITE_NAME=testhubapp -e WEBSITE_AUTH_ENABLED=False -e PORT=1880 -e WEBSITE_ROLE_INSTANCE_ID=0 -e WEBSITE_HOSTNAME=testhubapp.azurewebsites.net -e WEBSITE_INSTANCE_ID=9dead3715cfabf4121227c7b50ed47ff10d83fa4ce409893ec6050f6aee91951 -e HTTP_LOGGING_ENABLED=1 hubpoc/node-red-merakidata:latest
2021-05-02T20:32:13.969Z INFO - Initiating warmup request to container testhubapp_0_61835bb6 for site testhubapp
2021-05-02T20:32:16.292Z ERROR - Container testhubapp_0_61835bb6 for site testhubapp has exited, failing site start
2021-05-02T20:32:16.322Z ERROR - Container testhubapp_0_61835bb6 didn't respond to HTTP pings on port: 1880, failing site start. See container logs for debugging.
2021-05-02T20:32:16.383Z INFO - Stopping site testhubapp because it failed during startup.
