How can I add credential into my test function (Node-red-node-test-helper)?
Hi all,
First, I have a created node and it use credential value.
Normally, the credential is from input from screen.
Now I want to test, if I use invalid token with my request to destination server. It should return error 401.
Additional, I am not sure about characteristics of the data credentials that must be assigned to test function.
Below is main operation function of my created node.
function NodeLineNotify(config) {
        RED.nodes.createNode(this, config);
        this.accessToken = this.credentials.token;   <--- This line get credential section from input
        this.message = config.message;
        this.useExternalData = config.useExternalData;
Below is my test function
it("error token", (done) => {
        const flow = [
                type: "node-line-notify",
                message: "test",
                useExternalData: true,
                useImageUrl: false,
                useImageFile: false,
                useSticker: false,
                wires: [["n2"]]
            { id: "n2", type: "helper" }
        helper.load(nodeLineNotify, flow, () => {      <--- I am not sure about characteristics credential data for send into this function
            const n1 = helper.getNode("n1");
            const n2 = helper.getNode("n2");
            n1.on("call:error", (err) => {
                should.equal(err.lastArg.status, 401);
                should.equal(err.lastArg.payload, "Invalid access token");
                done();
            n1.receive({ payload: "test" });
