How can i calculate Memory usage in Node-red-Dashboard?
How can I calculate Memory usage in Node-red-Dashboard?
Do you want the memory use in a users browser or the memory of the nodes on the server?
I assume the former since you are asking about the Dashboard. To get that, you should open the browser's dev tools (F12 on most Windows/Linux browsers). Then you will find a tab called Memory. Using that you can take 1 or more snapshots of memory usage.
