I've got this simple piece of code to send 'mac address' and a 'name' to a table.
Is there a simple way to color the background of a cell ?
var lookupTable = {}
lookupTable = flow.get("mac_addresses");
let rec = {};
for (let key in lookupTable) {
if (lookupTable.hasOwnProperty(key) && key.includes(searchTerm)) {
rec = {"mac": key, "name": lookupTable[key]};
arr.push(rec)
msg.payload = arr;
What I would like to do is highlight the rows where there is text that includes "List of..."
I know I can use Tabulator, just wondered if there is a simple way to include a color defintion on this line?
David, this flow should show you how to do it. It is one of the example flows for node-red-node-ui-table
[{"id":"c292b5a561926c76","type":"inject","z":"7dd6e17128ddab20","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"Name\":\"<b>Yokoi</b>\",\"Age\":\"30\",\"Color\":\"lime\",\"Prog\":70,\"Star\":\"3\"},{\"Name\":\"<i>DCJ</i>\",\"Age\":\"50\",\"Color\":\"dodgerblue\",\"Prog\":\"45\",\"Star\":2,\"Pass\":false,\"web\":\"\"},{\"Name\":\"Nick\",\"Age\":\"40\",\"Color\":\"darkred\",\"Prog\":95,\"Star\":\"5\",\"Pass\":true,\"web\":\"http://nodered.org\"},{\"Name\":\"Oli\"}]","payloadType":"json","x":210,"y":80,"wires":[["c32ad00ed2c1833b"]]}]
Here is the result:
Where does the Amazon / Yeelight text come from in "mac_addresses" ?
I was just thinking you could add a property to show the device type, I do something similar. You could then use this to sort and filter the table
I have this format that I read from a text file into a flow variable ...
var lookupTable = {
"List of Yeelights":"List of Yeelights",
"78-11-DC-AA-57-3E":"Yeelight lounge left",
"78-11-DC-E1-28-12":"Yeelight lounge right",
"78-11-DC-AA-3B-72":"Yeelight lounge jungle",
"78-11-DC-A6-14-C8":"Yeelight lounge forest",
"List of Amazon devices":"List of Amazon devices",
"6C-56-97-E7-FD-DB":"Echo Dot (back) - Back bedroom",
"6C-56-97-11-9D-56":"Echo Dot (front) - Front bedroom",
etc...
I've tried this in a template node...
<div>
<h2 style="text-align: center;">MAC address lookup </h2>
<table id="table" border="1">
<tr>
<th>MAC address</th>
<th>Device Name</th>
</tr>
<tbody style="text-align: center">
<tr ng-repeat="row in msg.payload">
<td ng-if="row.mac.includes('List of')" , class="warning_red">{{row.mac}}</td>
<td>{{row.name}}</td>
</tr>
</tbody>
</table>
</div>
But for some reason the information appears in the wrong columns.
@dynamicdave
The problem here is that when the if statement evaluates to false the cell is not displayed.
try this - untested
<td ng-style="{'background-color': row.mac.includes('List of') ? 'red' : 'transparent'}">{{row.mac}}</td>
Thanks - that works a treat.
I guess you could add that to the second cell also if you wanted it to go all the way accross the table
You are too quick - I was just doing that.
Thanks for your input.
Great, well if you're sorted I will go and get my lunch now
A well deserved lunch. Thanks for your help.
E1cid
12
Or apply the style to the whole row
<div>
<tr>
</tr>
<tr style="{{(row.mac.includes('List of') ? 'background-color: red;' : '')}}" ng-repeat="row in msg.payload">
<td>{{row.mac}}</td>
</tr>
</tbody>
</table>
</div>
Thanks to everyone for their useful suggestions.
I'm really happy with the result now I've color-keyed it to my dashboard theme.
