Node-red-node-ui-table Row Background Color
For the "node-red-node-ui-table" Dashboard widget, I want to change a row's background color.
Using the examples, I built the following function, but so far, it does not work.
Requesting help for how to build the correct row background color command to the ui_table widget.
Alan
Here is the JSON object sent to the table node as "msg.ui_control":
{"action":"changeRowBackgroundColor","row":2,"backgroundColor":"#A6A6DF"}
And here is the flow used to build the JSON:
        "id": "550583f78c8ef99d",
        "type": "inject",
        "z": "c6730178a3d7066a",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "2",
        "payloadType": "num",
        "x": 2270,
        "y": 180,
                "16d1c80e4cdedfb4"
        "id": "16d1c80e4cdedfb4",
        "type": "function",
        "name": "Row Color",
        "func": "\n\nlet row = msg.payload; // Assuming the row element is in msg.payload\n\n// Create the ui_control object to specify the command\nmsg.ui_control = {\n    action: \"changeRowBackgroundColor\",\n    row: row,\n    backgroundColor: \"#A6A6DF\"\n};\n\nreturn msg;\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 2460,
        "y": 180,
                "3def4499718814cc",
                "e953d024949a0fcf"
To be more clear on my end goal:
I am looking at the example flow, for the ui-table, for changing background color, and want to replace the example's switch with a function, that I can input a search term and the column property for the search.
Any help in this direction is appreciated.
Below is the referenced Example's switch and "Table Paramater" function.
Alan
        "id": "c585e7a1.dfc648",
        "type": "ui_button",
        "z": "569288c052d73ac8",
        "group": "ff9fdb9a.7da098",
        "order": 9,
        "width": "4",
        "height": "1",
        "passthru": false,
        "label": "Format Numbers > 100",
        "tooltip": "using a rowFormatter callback function",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "function(row){         if(row.getData().numberValue>100){             row.getElement().style.backgroundColor = \"#A6A6DF\";         }     },",
        "payloadType": "str",
        "topic": "rowFormatter",
        "topicType": "str",
        "x": 612,
        "y": 2472,
                "16664cef.5b26b3",
                "b2b801ac9636df9c"
        "id": "16664cef.5b26b3",
        "type": "function",
        "name": "table paramter",
        "func": "msg.ui_control = {tabulator:{}};\n\n//workaround that buttos can`t deliver empty strings\nif (msg.payload.hasOwnProperty('payload')) {\n    msg.payload=msg.payload.payload;\n}\n\nmsg.ui_control.tabulator[msg.topic]=msg.payload;\ndelete msg.topic;\nmsg.payload=null;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 922,
        "y": 2489,
                "2e6a6379.742abc",
                "b8d75d24.6cbed"
        "id": "b8d75d24.6cbed",
        "type": "debug",
        "name": "table input",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "ui_control",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 1150,
        "y": 2489,
        "id": "ff9fdb9a.7da098",
        "type": "ui_group",
        "name": "TEST",
        "tab": "7dcc246f.ee661c",
        "order": 1,
        "disp": false,
        "width": "8",
        "collapse": false
        "id": "7dcc246f.ee661c",
        "type": "ui_tab",
        "name": "TEST",
        "icon": "dashboard",
        "order": 12,
        "disabled": false,
        "hidden": false
I found a solution.
In the example ui_table flow, a switch was sending a string to the "table paramter" function.
The string was function code, used in "table paramter" to search the table's column property for the search term.
My solution was to build a function to replace the switch's msg.payload string, and using implicate variables to add dynamic inputs for the search field's object and search term. Here is the function code:
let search_value = "Line #3";
let row_property = "textValue";
msg.payload = `function(row){
    if (row.getData().${row_property} === "${search_value}") {
        row.getElement().style.backgroundColor = "#A6A6DF";
msg.topic = "rowFormatter";
Below is the flow.
Alan
        "id": "d58cacbe28fde723",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "trigger",
        "x": 1170,
        "y": 2660,
                "f451b66417a5745c"
        "id": "f451b66417a5745c",
        "type": "function",
        "name": "function 28",
        "func": "\n\n\nlet search_value = \"Line #3\";\nlet row_property = \"textValue\"; // Define the row_property\n\nmsg.payload = `function(row){\n    if (row.getData().${row_property} === \"${search_value}\") {\n        row.getElement().style.backgroundColor = \"#A6A6DF\";\n    }\n}`;\n\nmsg.topic = \"rowFormatter\";\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1330,
        "y": 2660,
                "76d1918126ac0f29",
                "16664cef.5b26b3"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "x": 922,
        "y": 2489,
                "2e6a6379.742abc",
                "b8d75d24.6cbed"
Followup Question
OK I have the column high lite color working as above.
Q - How do I send a second search term and row highlight color to the ui_table?
Now, when I send the second search term and color, the first color is removed.
I am following the same method as used in the ui-table example. I have included the example flow, with my added functions below.
Alan
        "id": "2e6a6379.742abc",
        "type": "ui_table",
        "name": "testTable",
        "order": 6,
        "width": "8",
        "height": 5,
        "columns": [
                "field": "rowNumber",
                "title": "Row Number 1",
                "width": "",
                "align": "left",
                "formatter": "rownum",
                "formatterParams": {
                    "target": "_blank"
                "field": "textValue",
                "title": "Text",
                "width": "",
                "align": "left",
                "formatter": "plaintext",
                    "target": "_blank"
                "field": "numberValue",
                "title": "Number",
                "width": "",
                "align": "left",
                    "target": "_blank"
        "outputs": 1,
        "cts": true,
        "x": 1140,
        "y": 2200,
                "1c377ea0.5801e1"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "x": 922,
        "y": 2489,
                "2e6a6379.742abc",
                "b8d75d24.6cbed"
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1150,
        "y": 2489,
        "id": "1c377ea0.5801e1",
        "type": "debug",
        "name": "table output",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "x": 1303,
        "y": 2200,
        "id": "b15c31a9.af37c",
        "type": "ui_switch",
        "name": "selectable",
        "label": "selectable",
        "tooltip": "",
        "order": 7,
        "width": 0,
        "height": 0,
        "passthru": true,
        "decouple": "false",
        "topic": "selectable",
        "style": "",
        "onvalue": "true",
        "onvalueType": "bool",
        "onicon": "",
        "oncolor": "",
        "offvalue": "false",
        "offvalueType": "bool",
        "officon": "",
        "offcolor": "",
        "x": 562,
        "y": 2285,
                "16664cef.5b26b3"
        "id": "75207e8d.c54d4",
        "name": "movableColumns",
        "label": "movableColumns",
        "tooltip": "",
        "order": 8,
        "width": 0,
        "height": 0,
        "passthru": true,
        "topic": "movableColumns",
        "style": "",
        "onvalue": "true",
        "onicon": "",
        "oncolor": "",
        "officon": "",
        "offcolor": "",
        "x": 592,
        "y": 2336,
                "16664cef.5b26b3"
        "order": 9,
        "width": "4",
        "height": "1",
        "passthru": false,
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "topicType": "str",
        "x": 612,
        "y": 2472,
                "16664cef.5b26b3",
                "b2b801ac9636df9c"
        "id": "f178c6fe.710ef8",
        "order": 5,
        "width": 0,
        "height": 0,
        "passthru": false,
        "label": "Fill demo data",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "icon": "",
        "payload": "[{\"textValue\":\"Line #1\",\"numberValue\":123.12},{\"textValue\":\"Line #2\",\"numberValue\":100},{\"textValue\":\"Line #3\",\"numberValue\":50}]",
        "payloadType": "json",
        "x": 582,
        "y": 2200,
                "2e6a6379.742abc"
        "id": "2403f929.df4006",
        "order": 11,
        "width": "4",
        "height": "1",
        "passthru": false,
        "label": "inject Tooltips callback",
        "tooltip": "cell.getColumn().getField() + \" - \" + cell.getValue();",
        "color": "",
        "bgcolor": "",
        "icon": "",
        "payload": "function(cell){return  cell.getColumn().getField() + \" - \" + cell.getValue(); },",
        "topic": "tooltips",
        "x": 602,
        "y": 2574,
                "16664cef.5b26b3"
        "id": "f6c68c45.58003",
        "order": 12,
        "width": "4",
        "height": "1",
        "passthru": false,
        "label": "clear Tooltips callback",
        "tooltip": "empty string is not possible! so use a single space",
        "color": "",
        "bgcolor": "",
        "icon": "",
        "payload": "{\"payload\":\"\"}",
        "x": 602,
        "y": 2608,
                "16664cef.5b26b3"
        "id": "d2b29dda.60a5a",
        "order": 13,
        "width": "4",
        "height": "1",
        "passthru": false,
        "label": "reformat Number column",
        "tooltip": "inject additional paramters to numberValue column",
        "color": "",
        "bgcolor": "",
        "icon": "",
        "payload": "[{\"field\":\"numberValue\",\"formatterParams\":{\"min\":0,\"max\":200,\"legend\":\"function (value) {     if (value<100) return \\\"<span style='color:#FF0000;'>\\\"+value+\\\"</span>\\\";     else return \\\"<span style='color:#000000;'>\\\"+value+\\\"</span>\\\";  }\",\"legendAlign\":\"center\"},\"formatter\":\"progress\",\"topCalc\":\"function(values, data, calcParams){     var total = 0;     var calc = 0;     var count = 0;     data.forEach(value => {         total+=Number(value.numberValue);         count++;     });     if (count>0) calc=(total/count).toFixed(2);     return `${calc} (avg)`; }\",\"headerTooltip\":\"avarage\"}]",
        "topic": "columns",
        "x": 612,
        "y": 2676,
                "16664cef.5b26b3"
        "id": "7b6490b3.cd9c7",
        "type": "function",
        "name": "callback function(s)",
        "func": "// how to use the editor to write callback functions\n// DO NOT wire this into your flow!\n// copy / paste \"function( ... }\" into the correct calback parameter\n// use the \"debugger\" statement to debug your callback inside your browser\n\nvar topCalc = function(values, data, calcParams){\n    var total = 0;\n    var calc = 0;\n    var count = 0;\n    data.forEach(value => {\n        total+=Number(value.numberValue);\n        count++;\n    });\n    if (count>0) calc=(total/count).toFixed(2);\n    return `${calc} (avg)`;\n}\n\nvar legend = function (value) {\n    if (value<100) return \"<span style='color:#FF0000;'>\"+value+\"</span>\";\n    else return \"<span style='color:#000000;'>\"+value+\"</span>\"; \n}",
        "outputs": 1,
        "noerr": 0,
        "x": 932,
        "y": 2608,
        "id": "91506d4b.4956a",
        "type": "comment",
        "name": "Intentionally not wired into the flow!",
        "info": "use the editor to write callback functions\n\nDO NOT wire this into your flow!\n\ncopy / paste `function( ... }` into the correct calback parameter\nuse the `debugger` statement to debug your callback inside your browser\n",
        "x": 982,
        "y": 2574,
        "id": "732afcea.f728f4",
        "order": 14,
        "width": "4",
        "height": "1",
        "passthru": false,
        "label": "reset Number column",
        "color": "",
        "bgcolor": "",
        "icon": "",
        "payload": "[{\"field\":\"numberValue\",\"formatter\":\"plainText\",\"topCalc\":\"\",\"headerTooltip\":\"\"}]",
        "topic": "columns",
        "x": 602,
        "y": 2710,
                "16664cef.5b26b3"
        "id": "89cca7ea.7fc998",
        "order": 15,
        "width": "4",
        "height": "1",
        "passthru": false,
        "label": "add/show id column",
        "tooltip": "add a new column",
        "color": "",
        "bgcolor": "",
        "icon": "",
        "payload": "[{\"field\":\"id\",\"title\":\"id\",\"visible\":true,\"formatter\":\"plainText\"}]",
        "topic": "columns",
        "x": 602,
        "y": 2778,
                "16664cef.5b26b3"
        "id": "32a3c4ad.1b85fc",
        "order": 16,
        "width": "4",
        "height": "1",
        "passthru": false,
        "label": "hide id column",
        "tooltip": "hide id column (it is not possible to delete a existing column definition)",
        "color": "",
        "bgcolor": "",
        "icon": "",
        "payload": "[{\"field\":\"id\",\"title\":\"id\",\"visible\":false,\"formatter\":\"plainText\"}]",
        "topic": "columns",
        "x": 582,
        "y": 2812,
                "16664cef.5b26b3"
        "id": "25247f4b.cc7ec",
        "type": "inject",
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "true",
        "payloadType": "bool",
        "x": 416,
        "y": 2336,
                "75207e8d.c54d4",
                "bd3fd382.a2aa9"
        "id": "18ed8d27.bf00a3",
        "order": 10,
        "width": "4",
        "height": "1",
        "passthru": false,
        "label": "reset Numbers > 100",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "topicType": "str",
        "x": 602,
        "y": 2506,
                "16664cef.5b26b3",
                "b2b801ac9636df9c"
        "id": "bd3fd382.a2aa9",
        "name": "headerVisible",
        "label": "headerVisible",
        "tooltip": "",
        "order": 7,
        "width": 0,
        "height": 0,
        "passthru": true,
        "topic": "headerVisible",
        "style": "",
        "onvalue": "true",
        "onicon": "",
        "oncolor": "",
        "officon": "",
        "offcolor": "",
        "x": 582,
        "y": 2387,
                "16664cef.5b26b3"
        "id": "b2b801ac9636df9c",
        "type": "debug",
        "name": "debug 419",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "x": 920,
        "y": 2360,
        "id": "53eb3820bc2480e5",
        "type": "function",
        "name": "function 27",
        "func": "\n// Check if row.getData().numberValue is greater than 100\nif (msg.row && msg.row.getData().numberValue > 100) {\n    // Set the background color of row.getElement()\n    msg.row.getElement().style.backgroundColor = \"#A6A6DF\";\n\n    // Create a string representation of the result\n    msg.payload = \"NumberValue is greater than 100\";\n} else {\n    msg.payload = \"NumberValue is not greater than 100\";\n}\n\n// Return the modified msg object\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1030,
        "y": 2900,
                "16664cef.5b26b3"
        "id": "dea0f795461039e1",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 850,
        "y": 2880,
                "53eb3820bc2480e5"
        "type": "function",
        "name": "Set Background",
        "func": "\n\n\nlet search_value = \"Line #1\";\nlet row_property = \"textValue\";\nlet color = \"blue\"; \n\nmsg.payload = `function(row){\n    if (row.getData().${row_property} === \"${search_value}\") {\n        row.getElement().style.backgroundColor = \"${color}\";\n    }\n}`;\n\nmsg.topic = \"rowFormatter\";\n\nreturn msg;\n\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1340,
        "y": 2660,
                "76d1918126ac0f29",
                "16664cef.5b26b3"
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 1170,
        "y": 2660,
                "f451b66417a5745c"
        "id": "76d1918126ac0f29",
        "type": "debug",
        "name": "debug 420",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1560,
        "y": 2660,
        "id": "485d98d42ed3b072",
        "type": "function",
        "name": "function 29",
        "func": "\n\n\nlet search_value = \"Line #3\";\nlet row_property = \"textValue\"; \n\nmsg.payload = `function(row){\n    if (row.getData().${row_property} === \"${search_value}\") {\n        row.getElement().style.backgroundColor = \"#A6A6DF\";\n    }\n}`;\n\nmsg.topic = \"rowFormatter\";\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1370,
        "y": 2560,
        "id": "bac3f29f25577c66",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 1230,
        "y": 2760,
                "14ae924053e48278"
        "id": "12cf93c9b3bde1ba",
        "type": "debug",
        "name": "debug 421",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1670,
        "y": 2760,
        "id": "14ae924053e48278",
        "type": "function",
        "name": "Clear Hi Light",
        "func": "\n\nmsg.payload = {\"payload\": \"\"};\n\nmsg.topic = \"rowFormatter\"\n\n\nreturn msg;\n\n\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1430,
        "y": 2760,
                "12cf93c9b3bde1ba",
                "16664cef.5b26b3"
        "type": "ui_group",
        "name": "TEST",
        "order": 1,
        "disp": false,
        "width": "8",
        "collapse": false
        "type": "ui_tab",
        "name": "TEST",
        "order": 12,
        "disabled": false,
        "hidden": false
