Hi everybody!
I'm configuring some data in 2 different flows, and my goal is to change my flow when the user clicks in a button, is it possible to do that inside a function?
Thanks in advance!
Hi everybody!
Thanks in advance!
I would imagine so.
I apologize, my question was not understandable or is it not possible to change the flow?
what do you mean by "change the flow"
I want to change my user's view to another flow without him having to go to the navbar to select
Just to clarify - do you mean in the Node-RED editor (where users create their flows), you want to be able to change the tab being shown?
Or is this related to Node-RED Dashboard?
Where is that button shown? Is it part of a flow? Or some custom UI element you are adding to the editor?
If you do mean the dashboard then all you need to do is use the ui-control node and send the name of the "TAB" you want to switch to.
So if using a button, set the button payload to the name of the tab you want, and feed that into the ui-control node.
