I downloaded the flow "PWM Control LED" from the Node-Red page [https://flows.nodered.org/?term=gpio&num_pages=1] and imported:
[{“id”:“fde7314.d38d4d”,“type”:“rpi-gpio out”,“z”:“b73e866c.ea2e08”,“name”:“LED 2 on BCM7”,“pin”:“26”,“set”:"",“level”:“0”,“out”:“pwm”,“x”:593,“y”:81,“wires”:[]},{“id”:“216a7c2c.b2864c”,“type”:“inject”,“z”:“b73e866c.ea2e08”,“name”:“Off”,“topic”:"",“payload”:“0”,“payloadType”:“num”,“repeat”:"",“crontab”:"",“once”:false,“x”:149,“y”:79,“wires”:[[“fde7314.d38d4d”]]},{“id”:“85150548.334f38”,“type”:“inject”,“z”:“b73e866c.ea2e08”,“name”:“5%”,“topic”:"",“payload”:“5”,“payloadType”:“num”,“repeat”:"",“crontab”:"",“once”:false,“x”:162,“y”:135,“wires”:[[“fde7314.d38d4d”]]},{“id”:“db754534.4d67e”,“type”:“inject”,“z”:“b73e866c.ea2e08”,“name”:“30%”,“topic”:"",“payload”:“30”,“payloadType”:“num”,“repeat”:"",“crontab”:"",“once”:false,“x”:165,“y”:196,“wires”:[[“fde7314.d38d4d”]]},{“id”:“7fc774f5.49ca3c”,“type”:“inject”,“z”:“b73e866c.ea2e08”,“name”:“50%”,“topic”:"",“payload”:“50”,“payloadType”:“num”,“repeat”:"",“crontab”:"",“once”:false,“x”:167,“y”:252,“wires”:[[“fde7314.d38d4d”]]},{“id”:“c58e66c.40af618”,“type”:“inject”,“z”:“b73e866c.ea2e08”,“name”:“100%”,“topic”:"",“payload”:“100”,“payloadType”:“num”,“repeat”:"",“crontab”:"",“once”:false,“x”:165,“y”:310,“wires”:[[“fde7314.d38d4d”]]},{“id”:“f3b7be45.4ccfd8”,“type”:“comment”,“z”:“b73e866c.ea2e08”,“name”:“Pins”,“info”:"** Notes: **\nYou can’t have a pin in 2 flows\nIf you add a pin into a second flow with a different type then you’ll need to restart node-red",“x”:564,“y”:169.5,“wires”:[]}]
My question: how can I start the flow?
http: // localhost: 1880 /?
Kind Regards
Juergen B.
