How can I delete/stop Error: connect ECONNREFUSED 127.0.0.1:1883
I added Tasmota flows and created a sensor, but afterdeleting the sensor and the flow I get this error:
How can I stop it?
Is that appearing in the debug pane? If so click the node id above the error and it should take you to the offending node.
1883 is the MQTT port. Are you using MQTT?
In the dropdown menu select Config Nodes and click Unused at the top and see if you have any unused mqtt config nodes. If you have then click each one and hit delete to get rid of them. Then deploy.
Thank you! I was able to delete the node in HA integration entities.
