Hello!
I am trying to setup an entity within HA from Node-Red but I am getting this error:
"Sensor update attempted without connection to server."
I have other entities that are being updated and pushed to HA just fine in another flow, I am not sure what the issue is on this flow.
I am using an 'mqtt in' node, some switch nodes to sort some devices, and finally, a sensor HA entity node.
Not sure where the Node-Red logs are located or where it would be a good place to start troubleshooting.
HAOS via VM in ESXI:
Home Assistant 2022.7.3
Supervisor 2022.07.0
Operating System 8.2
Frontend 20220707.0 - latest
Node-Red add-on
Current version: 12.0.2
Companion integration using HACS
v1.0.9
