How can I do? If i want a debug node to show status when fins protocol get timeout
If i want a debug node to show status when fins protocol get timeout , How can i do?
Hi, one method is to modify the code of the node.
For example, I have a serial node which show the connect status.
View the code of this node, you may find out the corresponding js code below:
Next step, you may add your own code , to output the key status you're interesting in to a debug node or so.
Add a status node with a debug node. It will propagate the status, color and the text
@magicfire same for you.
Thanks, I tried and got the status.
Learned something new :wink:
